Warranty an oil filter?
How can they even offer that, they can't tell if it's bad or not.
Thats like me buying a new air filter, running my truck through the baja 1000 and taking it back out and asking for a warranty afterwards because it's now dirty. The filter did the job it's suppose to do, how could anyone warranty a part that does exaclty what it's suppose to do but in a short time period.
^my thoughts exactly. Broken or used - pick one
I thought this thread would've been closed by now lol. Now there's a chance I may have over tightened the oil filter. I remember using the filter removal tool to tighten it with, but I feel like I didn't do it that much. I know you're supposed to use your hands to tighten it, but it didn't feel tight enough. I do know it wasn't to the point where the filter wouldn't turn anymore. It isn't leaking or anything, but should I bee too concerned?
Seriously ? Lmao
On topic, i use k&n oil filters
Just tighten it You're the one taking off it later. You decide !
ive always been told the right way to install a filter is to wet the rubber ring with oil, then fill it when you can and screw it on till snug, then a 1/4 turn more.
to tight and the seal gets messed up and can blow out, to loose and yeah, it can leak too.
There is usually a graphic on the filter itself that shows you exactly what to do... usually hand tight then 1/4 turn or whatever it shows on the filter itself. Personally I just snug them with the oil filter wrench, after a lil oil on the ring just as Scotty described.
I think the most crucial part of any oil filter change is ensuring that the rubber ring came off with the old filter. I know a neighbor that installed a filter with the old rubber gasket still attached to the motor. His daughter drove it, oil leaked out between the gaskets, low oil light was ignored and engine was destroyed. He was pissed... but if you let an average woman use your car, your maintenance better be top-notch.
I agree with what impala and Scott said, I use wix filters since they are the same as the mobil1, K&N is also good. The big deal is about the oil, I loved AmSoil in my camaro, but I am not about to buy it for a cheap beater car.
