Thread: Guess why my car produces 0 boost. Taking bets.
Page 1 of 9 123 ... LastLast
Results 1 to 20 of 178
  1. #1 Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    Alright so I've just about done anything possible to figure out why my car will not run to its full potential. Let's try to stay on target.
    so what is your guess?
  2. #2 Re: Guess why my car produces 0 boost. Taking bets.
    Buffalo
    Zero boost? None at all?
  3. #3 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    The most I have seen in a while is 5psi that was a while ago. This evening it was 1.0 and on a from a start run to 90 mph was .5 psi..... With the bypass locked shut.
  4. #4 Re: Guess why my car produces 0 boost. Taking bets.
    Buffalo
    Oh. I was gonna say just run 1 vacuum line to the top of the bbv and remove the lower - so it's based off vacuum alone
  5. #5 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    No belt on blower? You some how routed it so it spins backwards?
    I think I made more boost than you when I was n/a.
    Top Swapped 01 Imp
  6. #6 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    Bad boost gauges?
    Top Swapped 01 Imp
  7. #7 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    Map (T app) and mechanical both read the same.
  8. #8 Re: Guess why my car produces 0 boost. Taking bets.
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Boost leak? what's the SC gasket look like? Somehow the LIM or SC are warped and boost be leaking from the mating surface?
  9. #9 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    Spun a bearing in the rotor pack?? Never heard that happen, but I guess its plausible.
    No strange noises of any kind?
    Top Swapped 01 Imp
  10. #10 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    Gasket was maybe bad. Both surfaces are under .005" using feeler gauges. RTV'dit back on last weekend. No change.
  11. #11 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by bandook View Post
    no weird noises. The only time I have ever seen this was when the driveshaft stripped from the drive end for the coupler.
  12. #12 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    Wait, are we guessing because you know what the answer is, or are we helping you sleuth this?
    Top Swapped 01 Imp
  13. #13 Re: Guess why my car produces 0 boost. Taking bets.
    Feb 2013
    37.295091, -121.930053
    i would say large vac leak
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  14. #14 Re: Guess why my car produces 0 boost. Taking bets.
    Mar 2015
    Franklin, TN
    I am guessing we are helping him sleuth it.
    You RTV'd it right? Black, red, gray or Honda? Also did you let it cure a little before putting the mating surfaces together? Also how soon did you drive after putting the SC back on with the RTV? If it did not fully cure before use you might have blown out some RTV. Done this on an exhaust before.
  15. #15 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    I don't fully know the answer but I am suspecting the driveshaft to coupler drive is toast.
    So your helping me sleuth this too. I've replaced everything from the PCM to MAF to baro and MAP sensors along with all the other vacuum leak tests.
  16. #16 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    Blue RTV, had a friend set the blower within 15 minutes and torqued the bolts in sequence at half the torque value then back to the full 17 ft/lbs. Waited 5 then ran around them again. Sat for 5 hours while I installed everything in place and waited. Then put the belt on and went for a drive.
  17. #17 Re: Guess why my car produces 0 boost. Taking bets.
    what are you using to read boost what are you using to scan? what has changed since it last worked properly? lets all keep taking a shot in the dark and guess since the op hasn't given enough info.....
  18. #18 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    Is it sloppy when you turn it back and forth? Would it even be possible for it to totally fail without making horrible noises? I think the nubs on the drive gear and the nubs on the nose shaft would hit each other?
    Top Swapped 01 Imp
  19. #19 Re: Guess why my car produces 0 boost. Taking bets.
    Apr 2015
    Columbus, OH
    Quote Originally Posted by 98BrokeMyCarVet View Post
    He already said his mechanical gauge reads the same as torque pro...
    And he actually helps others on the forum so I don't mind helping him brain storm.
    Top Swapped 01 Imp
  20. #20 Re: Guess why my car produces 0 boost. Taking bets.
    GXP Level Member
    Mar 2015
    Tomball
    I mi have posted more information on this car and everything that I have done for the last 2 months I will link them here in a minute. There are charts and graphs and they never get a response.
    if you had read any of this it already states what I am using to read boost. The Torque app and a mechanical gauge.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  3. Taking out the cat
    By Jakescoots in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2010, 10:26 AM
  4. Free sports bets, real cash...
    By GAFF in forum Off Topic Discussion
    Last Post: 02-22-2009, 12:34 PM
  5. Who's taking bets?
    By Reptile in forum Off Topic Discussion
    Last Post: 01-15-2008, 07:57 PM
