Thread: Steering wheel noise when turning
Results 1 to 11 of 11
  1. #1 Steering wheel noise when turning
    Nov 2011
    Indiana, PA
    Ok this just started, when I turn the wheel I get a whrul whurl noise and only when turning... it sounds like rough vinyl rubbing together.. it is not coming from the steering pump, the pump has been replaced and it is still there.
    I'm also getting a similar noise although much quieter when stopping once you get to about 4 MPH then let it roll stop you can hear a similar noise outside coming from the front wheels like vinyl rubbing.. the noise stops when you get stopped, you can hear it as you speed up to about 5MPH then after that the noise is gone...
    what in the world would make a noise like this in two different places? the wheel is concerning me the most... I've already had the rack/steering gear replaced once when the car was new for GRRRRR like noises when turning... the steering pump has been replaced twice now (i don't think it needed to be either time but they always say they are sure that is the problem, so far it hasn't fixed it)
  2. #2 Re: Steering wheel noise when turning
    St. Louis
    Might be a wheel bearing starting to go. Jack up the front and and push/pull on the tire at the 12 and 6 o'clock position. If you have play, then bearing it is. Have you replaced the brakes recently?
  3. #3 Re: Steering wheel noise when turning
    Nov 2011
    Indiana, PA
    Quote Originally Posted by FordMan77 View Post
    actually yes I did replace the front pads a few months ago
  4. #4 Re: Steering wheel noise when turning
    Aug 2013
    arlington, tx
    Might wanna take a video of the noise so we can get a better idea
  5. #5 Re: Steering wheel noise when turning
    Nov 2011
    Indiana, PA
    was going to record it tonight, but phone battery died so have to wait... but as I turn the wheel it sound exactly like the sound you get when you pull a seat belt out... that whrillll noise... it does not sound like a bad pump, it sounds like the noise is coming from inside the wheel I can't hear anything from the engine bay when the wheel is turned
  6. #6 Re: Steering wheel noise when turning
    Aug 2013
    arlington, tx
    That definitely sounds like a bearing. Whenever you're driving, does the noise go away when you switch lanes or pull a certain direction? Also does the noise increase as you increase speed?
  7. #7 Re: Steering wheel noise when turning
    Nov 2011
    Indiana, PA
    I really only notice the noise at lower speeds.. say 20mph or below, above that nothing
  8. #8 Re: Steering wheel noise when turning
    Oct 2011
    Toledo, OH
    Possible it's your strut mounts rubbing. When I did a full rebuild last year I only greased the bearings. When I put my Vogtlands on this week I greased everything and the noise went away.
    7"
  9. #9 Re: Steering wheel noise when turning
    hangover park IL
    strut mounts will give a "scrunt" type sound but a buzzing/whine may be the HP ps hose touching the firewall.
    there's a TSB covering this complaint. tighten the hardline to the pump outlet at a higher angle to move the hose away from the firewall.
    it can generally be observed with the hood open and a TRUSTED friend inside turning the wheel. you can lay across the engine bay (do it with a cold engine) and drive at slow speeds while turning.
    ~James~ Psychotic Gearhead
  10. #10 Re: Steering wheel noise when turning
    Apr 2015
    Columbus, OH
    Keyword, "trusted" friend. This is what happens when you pick the wrong guy...
    Top Swapped 01 Imp
  11. #11 Re: Steering wheel noise when turning
    Nov 2011
    Indiana, PA
    I'm going to add to this a bit since I still haven't figured it out... and the mechanics keep replacing parts that aren't fixing the issue... still...
    I noticed that it only makes this vinyl rubbing noise when turning to the left while moving... at the same speed turning to the right no noise, make another left noise again... its like a shurllll shurllll shurlllll noise... it's definitely not coming from the steering pump... after replacing that again I know it's not the pump because its still the same noise
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. Rpm drops down when turning steering wheel
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 11-16-2013, 10:59 AM
  3. Clunking noise when turning wheel?
    By Hippo Machine in forum General Tech Discussion
    Last Post: 09-16-2012, 02:02 PM
  4. Clunk while turning steering wheel
    By Z28 in forum General Tech Discussion
    Last Post: 03-31-2011, 12:57 PM
  5. Turning/Steering Noise
    By chisels1 in forum General Tech Discussion
    Last Post: 06-17-2009, 06:38 AM
