Thread: door lock not unlocking
Results 1 to 4 of 4
  1. #1 door lock not unlocking
    Nov 2011
    Indiana, PA
    I have a base 2008 GP, and this just started yesterday... the drivers side rear door when you tell it to unlock via the front switch or key FOB does not unlock... the lock pull stays down, but if i manually pull it up to unlock it then do a lock it goes down fine... unlock command again, stays down... so it will lock fine but not unlock unless manually pulled up...
    any reason for this to start out of no where? any fixes? or do i have to change to put in a new actuator?
  2. #2 Re: door lock not unlocking
    GTP Level Member
    Aug 2012
    st louis park, MN
    Did you ever find a solution? This just started occurring on my 2008 gp over the weekend. Might send you a PM as well.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  3. #3 Re: door lock not unlocking
    Nov 2011
    Indiana, PA
    http://www.gmpartsdirect.com/oe-gm/25955873
    25955873 Driver side rear side door lock; includes actuator
    had to change that part
  4. #4 Re: door lock not unlocking
    GTP Level Member
    Aug 2012
    st louis park, MN
    Thank you for the post update and PMs! It starting working again for the time being.
  1. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  2. door lock help
    By dudleyc05 in forum General Tech Discussion
    Last Post: 01-29-2011, 05:29 PM
  3. unlocking lock screen for iphone.
    By tazyboy28 in forum Off Topic Discussion
    Last Post: 05-10-2010, 12:29 AM
  4. Lock-up not unlocking
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 02:23 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
