Thread: sub frame bushings
Results 1 to 10 of 10
  1. #1 sub frame bushings
    May 2011
    winnipeg
    Do I need any special tools to change the front subframe mount bushings on my 01 grand prix? The noise is getting worse. Seems the noise gets quieter the warmer the outside temp gets warmer. Anybody experience
    this same thing or is it my imagination? Any and all help would be appreciated.
  2. #2 Re: sub frame bushings
    i had a clunk that was only there when it was super cold out. looks like it was the sway bar bushing. over winter i saw a small gap. now i dont see one, and the clunk is gone.
    as for the frame bushings, you need a jack, jack stands, and a 18 mm socket. taking off the dog bones from one side cant hurt either, 15 mm socket.
  3. #3 Re: sub frame bushings
    Arizona
    Get a 3jaw puller from auto zone and a flat head screwdriver and a hammer for the front bushings. Hammer the flat head in between the lip of the frame and bushing until you get enough gap to stick the puller on it
  4. #4 Re: sub frame bushings
    May 2011
    winnipeg
    I have changed the lower control arms, strut mounts and sway bar mount bushings and end links, still noise. Has anyone written a how to change sub frame mount bushings, step by step? I don't want to cause myself more grief.
  5. #5 Re: sub frame bushings
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by dlk View Post
    Never done these on a W-Body, just an H-Body... but I'd imagine it would be similar. Use lots of penetrating oil, those bolts get rusted in really bad. Not sure about what you're in for if one of those bolts break off in the body, but I can't imagine it would be fun.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: sub frame bushings
    Arizona
    I literally just explained it
  7. #7 Re: sub frame bushings
    Knoxville, TN
    Quote Originally Posted by 91parkave View Post
    Why would you need a 3-jaw puller for for the subframe bushings? Maybe we are talking about two different things... as I recall, to remove a bushing, you just have to support the subframe with a jack stand, remove the bolt holding in the bushing and backing, and the bushing should come right out by hand.
  8. #8 Re: sub frame bushings
    Arizona
    The front subframe bushings definitely do not come by hand
  9. #9 Re: sub frame bushings
    Knoxville, TN
    Mine did.... maybe it was because they were totally obliterated by the previous owner. lol
  10. #10 Re: sub frame bushings
    May 2011
    winnipeg
    thanks for all the input, I replaced everything else so I guess the sub frame bushings are next because the noise is driving me crazy. The ride used to be so quiet, I love the car and don't want to get ridd of it
  1. Sub frame bushings
    By Peder in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2014, 11:23 AM
  2. Will a 04 Sub frame fit in my 97?
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 12-19-2012, 11:07 PM
  3. need LCA's/bushings but want poly bushings...
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2011, 09:24 PM
  4. GMPP Sway bar frame bushings???
    By Toasty in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2009, 02:52 PM
  5. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
