Thread: Did I just screw up lol?
Results 1 to 8 of 8
  1. #1 Did I just screw up lol?
    Buffalo
    Question. I was installing my head studs late last night. I chased the threads , cleaned them , coated with thread sealant. Coated the studs , installs hand tight , then seated to 10ft/lbs. Cleaned up excess sealant and started to spray my gaskets. Got side tracked and went home for the night.
    Having my morning coffee , I'm starting to think it was possible I made a bad choice. Should I have not let the sealant set up over night because I fear torquing the nuts down later today will or could crack the seal?
    Should I be concerned?
  2. #2 Re: Did I just screw up lol?
    Mar 2012
    NC
    No, apply another coat to the gaskets and put them on. Problem solved.
  3. #3 Re: Did I just screw up lol?
    Agreed...I always let the studs setup as long as you have available
  4. #4 Re: Did I just screw up lol?
    Panama City Beach, FL
    This.
  5. #5 Re: Did I just screw up lol?
    Apr 2015
    Columbus, OH
    Dunno if that copper spray ever really "sets". Seems to stay tacky.
    I'm jealous though. I debated but decided to just get bolts instead of studs. First time I ever used an angle gauge for tty bolts. It was a real pita doing the rear head. I could barely see the dial even with the block pulled forward. Front one should be much easier but if the heads ever come off I'm doing studs for sure.
    Top Swapped 01 Imp
  6. #6 Re: Did I just screw up lol?
    Buffalo
    perfect. Thanks guys. Going over there now to finish up!
  7. #7 Re: Did I just screw up lol?
    Nov 2011
    NY
    Thread sealant doesn't set up (dry) until heated over time. If you pulled studs, you'd find the thread sealant still pliable. If that's what you're asking... And usually, it's a good idea to let it all sit before start up anyways... Problems occur when people put an engine together and can't wait to start er up! Lolz... ; )
    Just my $.02
  8. #8 Re: Did I just screw up lol?
    Cant say I disagree here either. But in reality, most installs occur late in the evening, so the sleep pattern allows set time
  1. coolant screw up help
    By Logan541 in forum General Tech Discussion
    Last Post: 11-06-2013, 01:18 PM
  2. So how bad did i screw up??
    By BlackGT97 in forum General Tech Discussion
    Last Post: 02-19-2013, 10:29 PM
  3. idle set screw
    By hinge in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 01:15 PM
  4. Screw the dealership !!!
    By Beanz in forum The Rant Forum
    Last Post: 02-16-2010, 02:22 PM
