Thread: Have a p0141, Should i defouler to fix??
Results 1 to 4 of 4
  1. #1 Have a p0141, Should i defouler to fix??
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Have a p0141, Should i defouler the o2 senser to fix??
    Would a p0141 code mean clogged cat?
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  2. #2 Re: Have a p0141, Should i defouler to fix??
    Feb 2013
    Missouri
    No, P0141 is the heater circuit of the oxygen sensors, not the sensor's readings. IIRC the heater circuit is the same for both 02s, so you might have a problem with the connectors, might have a blown fuse, or one of the heaters might be bad (new sensors)
    http://engine-codes.com/p0141.html
  3. #3 Re: Have a p0141, Should i defouler to fix??
    Jan 2014
    United States
    Quote Originally Posted by Booba5185 View Post
    So youre saying that the heater circuit code pops on both sensors if there is a blown fuse or bad wiring only? I have a defouler and when I installed it, the CEL went off for a day or two, but then went back on since then due to bad wiring. I fixed the wiring and it still throws the heater code for both sensors. Maybe I have a blown fuse.
  4. #4 Re: Have a p0141, Should i defouler to fix??
    Or more likely one of your sensors is bad.
