Thread: urgent help.. break lights work but only when I make a complete stop
Results 1 to 7 of 7
  1. #1 urgent help.. break lights work but only when I make a complete stop
    Apr 2015
    brownwood tx
    Hello I have a 2006 grand Prix I recently bought from a guy.. Ive noticed on the dash it says service break apply sensor... My break lights come on only when i make a complete stop. They do not give off warning that im slowing down until im a 0 mph.. In the last month I have spent well over 700$ trying to fix the problem.. I've replaced the
    Brake switch-
    Brake pedal position sensor-
    Body control module-
    Checking all wires for short
    Another body control module
    Plus labor..
    I'm so tired of getting the run around I just need some real advice that will help my problem.
    Thank you
  2. #2 Re: urgent help.. breaks work but only when I make a complete stop
    Nov 2013
    Wisconsin!
    What do you mean they don't work until you're at 0?? You seem to be alive and typing so the brakes are working.....does the pedal go to the floor? Do you have to pump them to get them to work?
    Or are you talking about the brake lights?
  3. #3 Re: urgent help.. breaks work but only when I make a complete stop
    Sep 2014
    Worcester, MA
    Confused... if the brakes don't worked until you stop, how do you stop?
  4. #4 Re: urgent help.. breaks work but only when I make a complete stop
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Could use the E-Brake. My friend said his brakes went out on his 2005 Grand Prix Base and had to use his E-Brake to stop coming from an offramp.
  5. #5 Re: urgent help.. breaks work but only when I make a complete stop
    Apr 2015
    brownwood tx
    Yes sorry I meant break lights don't come on till I make a complete stop
  6. #6 Re: urgent help.. break lights work but only when I make a complete stop
    hangover park IL
    ~James~ Psychotic Gearhead
  7. #7 Re: urgent help.. break lights work but only when I make a complete stop
    I like to start out learning about the system.
    Stop Lamps
    The turn signal lamps are also used as stop lamps. The STOP/TURN/HAZARD fuse in the instrument panel (I/P) fuse block supplies battery positive voltage to the body control module (BCM) for the stop lamps.
    A 10-volt reference signal and a low reference signal is applied from the BCM to the brake pedal position (BPP) sensor. When the brake pedal is applied, the BPP sensor applies a signal to the BPP sensor signal circuit to the BCM. The BCM then applies battery positive voltage to the LR and RR stop/tail/turn lamps through the LR and RR stop/turn lamps supply voltage circuit. The BCM also supplies a battery positive voltage to the CHMSL through the stop lamp supply voltage circuit. The ground for the LR stop/tail/turn lamp is supplied from G301 The ground for the RR stop/tail/turn lamp and for the CHMSL is supplied from G302.
    There's clearly more info in what TurboSBC linked you to that isn't really explained in the above. Some good stuff there, it seems that likely either the reference is bad or you need to have the switch reprogrammed/relearned.
  1. How can you make the horn work with the key fob?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 12:51 PM
  2. Brake upgrade - What will I need to make this work?
    By Brooks in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2010, 08:33 PM
  3. Disconnect FM antenna to make mp3 player work better?
    By RobotBastard in forum Audio, Security & Visual Electronics
    Last Post: 09-10-2009, 01:32 AM
  4. Does it make sense to rebuild it before it breaks?
    By Burbman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 04:39 PM
  5. Less Breaks at work???
    By offroadfury6 in forum The Rant Forum
    Last Post: 10-30-2008, 06:16 AM
