Thread: GP Upper and Lower Intake Manifold Coolant Leaks
Results 1 to 12 of 12
  1. #1 Re: GP Upper and Lower Intake Manifold Coolant Leaks
    Many have.
    It's a stock replacement, just buy the revised manifold from whoever.
    Or are you talking about swapping on the aluminum L26 intake manifold? Because you can do that too.
    Also; aluminum elbows are just as simple as replacing the stock plastic units.
    If you're in there, might as well replace the lower intake gaskets too...and put in the metal ones instead of the plastic ones there to boot.
  2. #2 Re: GP Upper and Lower Intake Manifold Coolant Leaks
    Massachusetts
    Thanks Bluguy, I've ordered the metal lower intake manifold gaskets. I only want to do this one time. Just looking for any tips from those that have experience doing this so it goes smoothly with no issues.
  1. Upper/lower intake manifold upgrade
    By MEaston91 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2014, 05:05 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. tips/tricks. list for upper/lower intake manifold gasket job..
    By crod in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-30-2012, 12:51 AM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
