Thread: Cv axle replacement
Results 1 to 8 of 8
  1. #1 Cv axle replacement
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Easiest way to replace cc axle? My driver side has a boot that's torn so I'm going to relace whole thing. I have the outer tie rod off the inner tie rod. What's easiest way to do it? Remove caliper, Hub then get new one in?
    is the inner tie rod a lot to replace? Since I already have the outer off of it if it's easy enough I'll do that aswell.
    do I have to compress a quick struts spring to fit it on the car? It seemed like where it bolts in is about a inch higher than the one that was on the car.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: Cv axle replacement
    Remove the axle nut, remove the ball joint nut, pop the ball joint out, push the axle through the hub while lifting the whole knuckle to the side, pop axle out of transmission and thats pretty much it. You might have to remove the sway bar link to allow the control arm to push down enough.
  3. #3 Re: Cv axle replacement
    Aug 2012
    Brainerd, MN
    K that shouldn't be too hard. When I was trying to get part of it going I couldn't get the sway bar links to loosed. I had a socket on top and bottom
  4. #4 Re: Cv axle replacement
    There is a how to in the how to section.
  5. #5 Re: Cv axle replacement
    Aug 2012
    Brainerd, MN
    Ok I'll check it out getting a cv axle from Napa lifetime warranty sounds pretty good to me since I hear some people have to replace them often.
  6. #6 Re: Cv axle replacement
    Sep 2014
    chicago
    Just did mine, fairly easy. I ended up going back to autozone to rent a slide hammer because I couldn't pull the axle out by hand.
  7. #7 Re: Cv axle replacement
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by ayeb View Post
    I did the same thing wasted 3 hours trying to get it out. Took two minutes with slide hammer
  8. #8 Re: Cv axle replacement
    Sep 2014
    chicago
    Lol yea
  1. CV Axle Replacement
    By UCF04GPGTPCompG in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2013, 10:34 PM
  2. HELP! Really put myself into a pickle (cv axle replacement)
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 10-04-2011, 05:29 PM
  3. Axle replacement problem
    By Silver GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 04:35 PM
  4. Axle replacement, DIY?
    By Poil336 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2010, 11:03 PM
  5. Axle replacement.
    By DnaProdigy in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2009, 09:28 PM
