Thread: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
Results 1 to 11 of 11
  1. #1 Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    SE Level Member powerdpower's Avatar
    Dec 2014
    Brigham City, Utah
    At least I think it's the rear drivers side. So I was just driving along, when POP POP POP POP, so I start to slow down, then the popping slows at the same time. I get out, check the tires, try to wobble them, everything feels good. So I try to go real slow, and there is a slight wobbly feeling, and a little squeak, from what feels like the rear driver side wheel.
    The only thing I had done previously was park on a hill, properly with the parking break, and yes I took it off before moving again. I had also noticed last week some slight wobbling at high speed, but I threw that out as it was time for my tires to be rotated and balanced (which it is time to do anyway)
    Any ideas? First thing I can think of off the top of my head is a bearing or a control arm..
  2. #2 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Donating Users timboku's Avatar
    Montgomery, IL
    Did you check that the lug nuts
    are tight? Sounds like a loose lugnut.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Dec 2014
    Brigham City, Utah
    Just checked all the lugnuts, all super tight and secure. I think I may have to jack each corner up and feel for play in every tire.
  4. #4 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Any wiggle in the hub area? or tie rods?
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  5. #5 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Enfield, CT
    Quote Originally Posted by QuinlanGTP View Post
    There are no tie rods in the rear....
    Check the lateral links, trailing arm, and hub for play. Also grab the coil spring and pull and then push forward a few times to see if there is anything going on with the strut and mounts.
  6. #6 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    in a few days i bet we see the i lost a back wheel post. ive seen this happen 2 times on the board, bad hub fails, takes the wheel off, f's up the car body and the car behind you some times.
    jack the car up and start pushing and pulling the wheel around.
  7. #7 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Dec 2014
    Brigham City, Utah
    Wheel hub and bearing are good. Me and my neighbor think it is probably something going wrong with the emergency break. Will keep you all updated!
  8. #8 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    spin the tires jacked up, listen for the rub.
    if its a wobble feeling, its not the e brake.
    rotate your tires too, see if the wobble moves to the front of the car. tires have been known to just go bad and break a belt and egg a tire.
  9. #9 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Dec 2014
    Brigham City, Utah
    I have pulled on them to feel for wobble. I will try and spin them later today when I am back home. Tire won't fall off driving it, because I am not driving it till it is fixed...
  10. #10 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    good plan.
  11. #11 Re: Popping, slight squeaking, and possibly wobblyness from rear driver side tire.
    Dec 2014
    Brigham City, Utah
    Here is the update. I was able to drive it to my neighbors garage today and put it up on his lift. The hub checks out, lubed up the e brake cable just in case.
  1. noise from front driver side tire
    By tommygunz12 in forum General Tech Discussion
    Last Post: 05-18-2014, 09:41 PM
  2. Ticking/squeaking sound plus trans popping?
    By Bakerdd in forum General Grand Prix Discussion
    Last Post: 05-09-2013, 12:33 PM
  3. Smell gas/fuel on rear driver above tire
    By rocket in forum General Tech Discussion
    Last Post: 06-14-2012, 07:37 PM
  4. Noise in Front Driver-Side Tire Well
    By PsychOut in forum General Tech Discussion
    Last Post: 09-05-2009, 08:43 PM
