Thread: Stripped oil pan plug
Results 1 to 19 of 19
  1. #1 Stripped oil pan plug
    Jul 2016
    Michigan
    I just purchased a 2006 grand Prix GT. I wanted to change the fluids and make sure it's all fresh stuff. I flushed the coolant first with no problems.
    I ran into a great deal of problems with the oil change.... which typically is an easy job, at least on all the other vehicles I've owned.
    Anyways, the drain plug on this car is in a cramped space. It's location is on the rear of the oil pan between the transmission pan. I couldn't get a socket in that space with the ratchet on.
    So, it seemed to me like the only logical choice was to use the box end of a 13mm wrench. I got that on there snugly, I had to use a lot of force to get it to spin(yes lefty loosey), however the plug never moved.... it just stripped and rounded a bit.
    I guess the guy I bought it from must have waaay over-tightened this sob. I also tried to put a pair of vice grips on the plug. Again, the grips were spinning and the plug stayed put.
    I took it to an oil change place to see if they could get it, but they too couldn't get it... so now I'm not quite sure what to do next.
    Does anyone have any ideas or has anyone else ran into this? Real bad design having the plug in the location it is, real disappointed in that.
    Thanks in advance guys!
    Sent from my XT1254 using Tapatalk
  2. #2 Re: Stripped oil pan plug
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I know the location, and I know it sucks. Mine was stuck in there too. I used a 3/8 drive socket wrench adapter. No.. wait. I did use a wrench.
    There's no real way to get a swing on it with a hammer unless someone else knows a trick.
  3. #3 Re: Stripped oil pan plug
    While I don't agree about it being a poor location. that's my opinion.
    How about slotting it up the center and using a screwdriver as a lever to remove it and put in a new one.
  4. #4 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Whoever changed the oil last, put the plug in extremely tight. Like I said, a box end wrench didn't get the job done and neither did vice grips. Makes me wonder if the threads are damaged from over-tightening?
  5. #5 Re: Stripped oil pan plug
    Mar 2014
    Tucson
    Could you weld a nut to what's left of the bolt head?
  6. #6 Re: Stripped oil pan plug
    hammer and a chisel should bust it free, hitting the edge of the bolt in the proper direction to loosen it up. or a small pipe wrench would lock on it better then vice grips if its like round now.
  7. #7 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Quote Originally Posted by BrandonHall10 View Post
    That thought has crossed my mind for sure. I've got a buddy who does welding I'll see what he says.
  8. #8 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Thanks for the advice, I'll give that a whirl when I get home from vacation.
  9. #9 Re: Stripped oil pan plug
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by MSU View Post
    Are you using 12 point? Sometimes it is a difference maker. I'm thinking heat might be your friend.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: Stripped oil pan plug
    I do have six point box ends for when things are too tight like this.
    I'd drop a groove in it and use a flat head as a lever.
  11. #11 Re: Stripped oil pan plug
    Antioch, IL
    Pipe wrench never failed me, those things DIG in
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: Stripped oil pan plug
    Quote Originally Posted by ItHurtz View Post
    Animal
  13. #13 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Will try that. Thanks
  14. #14 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Thanks for input.
  15. #15 Re: Stripped oil pan plug
    Jan 2014
    AR
    Hmm, My drain plugs are all 15 MM. I use a long-reach wrench or two wrenches piggybacked for leverage. Ya might try again with the engine at operating temperature, if that hasn't already been tried. Sounds like pipe wrench will be the ticket though. Sure is strange that the drain plug is in a tight location on yours, 3800s are way out in the open. Something ain't right. Need pic.
  16. #16 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Quote Originally Posted by idrivejunk View Post
    I'll send pics with updates this weekend
  17. #17 Re: Stripped oil pan plug
    Matt the aluminum pan does put it a smidge closer to the trans pan, but it's not horrible.
  18. #18 Re: Stripped oil pan plug
    Jan 2014
    AR
    Ah, alum pan. Uh-oh. Another thing to try is to see if it will tighten... juuust barely, to break loose.
  19. #19 Re: Stripped oil pan plug
    Jul 2016
    Michigan
    Hey guys! Sorry I haven't updated in a while. I tried a pipe wrench as suggested and it worked like a charm. I really had to reef on that sob though. The last guy really over did it. Thanks for all the input fellas!
  1. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  2. stripped bolt
    By RamonGTX in forum Engine
    Last Post: 08-25-2011, 02:23 PM
  3. anyone know if if i stripped my rotors?
    By hardrocrick in forum General Tech Discussion
    Last Post: 07-17-2011, 07:08 PM
  4. Help! Stripped supercharger plug
    By ddsohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 04:01 PM
  5. Plastic oil pan - Plug stripped - Suggestions
    By drmurdoc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2010, 09:34 PM
