I bought a 2001 gpgt last weekend and I have a ses light on as well as abs and was hoping to get some input from people who know more about these cars than i do before i start ordering parts, would really appreciate any help.
noticeable symptoms: when i start it, it revs up a bit, like 1200-1600 then dies unless i give it gas, but it will usually start and run normally on the second try or after giving it gas, it stumbles a little bit for a second then will idle on it's own. once it's running the rpms surge during idle, from around 500 to 1k, it drives fine, until yesterday when it died while coming to stop, but started back up and ran fine the rest of the way home. The po had replaced the engine and trans with ones with around 100k on them, no knocking or anything, but the area was pretty far in the country, lot of dirt roads, car was muddy and the air filter is just, embarrassing, planning to get a k&n or spectere but heard the oil can cause problems with the maf sensor, should i stick with standard paper filters?
First code is p0102 mass or volume air flow A circuit. they said it gave the same code 3 times?
sounds straight forward, replace the maf, but that sounds to easy, and don't want to spend $150 on a sensor i don't need, was going to get some maf cleaner and see how that does, but was hoping to get input on this one as i have also read that the aftermarket mafs are junk and i should get a used one from a junk yard? based on the issues i am having along with the codes does it sound like it could be the maf? iac? map?
P0128 repeated twice, coolant thermostat temp below, i assume this is a failed t-stat that it stuck open, the car does take a while to get warm and stays on the cool side of the temp gauge. I plan to get a stant super stat, is the 180* t-stat a good choice, or should i get the 195? everything is stock right now, I might get a cai/wai in the future and possibly a cat back to make some noise but nothing to extreme.
p0440 evaporative emission, car had no gas cap when i bought it, did put one on there but haven't d/c battery to clear codes yet.
p1811 i read about this one, but haven't noticed it, read that a shift kit can fix it, but also read that it will show when scanned but not pop a MIL so it not really an issue to me as of right now as i'm just trying to get it passable for state safety and emissions testing.
C0035 left front wheel speed sensor circuit malfunction, sounds straight forward, replace the hub assembly, is there a recommended brand? i usually buy everything from advanced auto, but the drive works brand has mixed reviews and moog is expensive
