Thread: 98 grand prix gtp starts and dies
Results 1 to 20 of 27
  1. #1 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    My car was running great till today, it starts and runs a few seconds and quits, did the bend the tab trick for high speed fuel sencer, no difference, unplugged maf, no difference, after car quits I can hear the fuel pump working. any ideas?
  2. #2 Re: 98 grand prix gtp starts and dies
    The Boss Iceman6669's Avatar
    Jun 2011
    Did you try unplugging the MAF?
    2011 F-150 Yote powered
  3. #3 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    yes I did was gonna put one from my 99 in it but they are different, and if I try to give it gas it will run about one second longer, no pops or sputter it just dies
  4. #4 Re: 98 grand prix gtp starts and dies
    Jun 2011
    So when you just unplugged the maf and tried to start the car there was no change it how it acted?
  5. #5 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    none at all, well maybe ran 1 second longer lol if at all.
  6. #6 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    I guess I can take my fuel pump out of my other gtp and see if it makes a difference lol
  7. #7 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    And there is no codes.
  8. #8 Re: 98 grand prix gtp starts and dies
    Feb 2013
    37.295091, -121.930053
    it maybe the crank sensor
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    I was thinking that but thought they failed when car was hot, and would start again when it cooled down, on a side note, I have been hearing a clicking noise under the dash for about two weeks, and now when I was trying to start it I noticed I cant turn the heat on or up, is my main computer going bad maybe?
  10. #10 Re: 98 grand prix gtp starts and dies
    Feb 2013
    once they fail they wont throw a code. also if your thinking its the pump do you hear the pump when you turn the key to the on position? i had a fuel pump go and it would run for 2 seconds then die. was really easy to fix tho
  11. #11 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    when I first turn key I hear pump, after I motor quits I can hear it for a second, I do have a blown up gtp in garage ill try switching out pump this weekend, see if that does it, if not that I guess crank shaft sensor, unless any other ideas lol
  12. #12 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    Well I put in my other pump that I knows good, same thing going on, heat don't seem to turn on ether. and the hud has gone bright and dim in the past, If I do css , does it have to get it programmed after I get it in car?
  13. #13 Re: 98 grand prix gtp starts and dies
    why dont you figure out whats missing after it stalls? like does it have spark still, or is it out of fuel at the rail?
  14. #14 Re: 98 grand prix gtp starts and dies
    does the tach move when you crank the engine after it stalls?
  15. #15 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    when I start car tach goes to 1000, idles and car quits, if I give it gas it get to about 3000 then quit and tach just goes to zero when car quits, no jumpyness
  16. #16 Re: 98 grand prix gtp starts and dies
    pull the vac line off the fpr on the fuel rail, see if gas comes out the line, if nothing comes out sniff the vac line, to see if you smell gas. if you find any of that it need s new fpr.
  17. #17 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    nothing came out smells fine
  18. #18 Re: 98 grand prix gtp starts and dies
    try swapping the icm from that other car you got. see if that helps.
  19. #19 Re: 98 grand prix gtp starts and dies
    and double check the grounds on the tranny and the battery terminals are tight and clean.
  20. #20 Re: 98 grand prix gtp starts and dies
    Jun 2014
    minnesota
    no change,
  1. '03 Grand Prix starts then dies right away
    By Econdron in forum General Grand Prix Discussion
    Last Post: 02-28-2022, 11:42 PM
  2. 2004 grand prix gt starts then dies within 2 seconds (intermitten)
    By GRANDPRIX2004 in forum General Tech Discussion
    Last Post: 03-12-2013, 07:07 PM
  3. 1992 Richard Petty Edition Grand Prix Starts the dies
    By garthbjr in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-20-2011, 06:58 AM
  4. 1991 grand prix starts then dies after five minutes
    By oithebusiness in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2009, 12:54 AM
  5. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
