Thread: Stock motor, e85 how small of a pulley can be ran assuming custom tune
Results 1 to 20 of 32
  1. #1 Stock motor, e85 how small of a pulley can be ran assuming custom tune
    GT Level Member revin24's Avatar
    Apr 2013
    Flint, Mi
    All stock motor only full exhaust and k&n fipk on E85 how small of a pulley can be run obviously it needs to b tuned but let's just run it to the ragged edge what about a 3.0 or a 2.8 hmmmmmm
  2. #2 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Really? This is like the third or fourth "how small a pulley can i run" thread in the last week. It must be a rash or something going around.
    But alas, to answer, what year? L67 or L32? How is your car running now? Everything up to date maintenance wise?
    Hypothetically, with a full exhaust (including headers and hi flow cat) on a gev v maybe a 3.2. No headers 3.5. Gen III 3.1 maybe lower?
    Hard to say and these threads suck btw. SCAN THAT MOTHERF***** AND FIND OUT.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Apr 2013
    Flint, Mi
    It's going to b a junkyard motor series 2 just aren't going to have the money to do what I really want to do wasn't sure where to look to find a past thread that might have the answer in it but it will all be stock and I have aeroforce gauges to put in it
  4. #4 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Feb 2009
    flintnasty MI
    I run a 3.2 untuned on 42# injectors. I could probably run a 3.1 without any issues. Im stock with a hot air intake and ubend delete.
    Its faster than most gtp's with cam/headers/intercooler lol.
  5. #5 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Jan 2013
    Raleigh, NC
    I'm running a 42#'s as well, untuned for them on E85. It works. And on mine works pretty well. I stay at normally between 7.8 and 9.3 on my LTFT's. Sometimes goes up to 12.5 or 13.3 but rarely hits the max 16.4. I ran a 70/30 blend of E85(30) and 93(70) before i switched over and i would be about the same. Runs better now. Its high, but the car runs really strong and has no knock.
    I went from a 3.5 with headers and about 2* of knock to a 3.3 with none. And i'm sure i could go to a 3.2 but i'm just playing it safe. BUT I SCAN WITH TORQUE EVERY TIME I GO OUT. And if i start to see weird trims or any big knock i will pulley up. That is literally the only way to do it.
    And just browsing the Supercharged engine section of this forum would have brought you probably hundreds of results about this same topic. But still. Good luck.
  6. #6 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Apr 2013
    Flint, Mi
    Do u think I can get u to tune this thing this summer when I pop this motor in
  7. #7 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Guess you're screwed when that cam/headers/IC gtp runs race gas, eh darkhorizon? I mean that takes away the single advantage you have, running race gas on a daily basis. Never would've guessed 105 octane could make up for 3 of the best mods you could do, lol.
  8. #8 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    you have no idea do you? let me guess never drove an e85 car before huh?
    mine makes 330whp/400wtq No god damn intercooler on stock heads with a gen5 2.8 headers s1x cam and some 60# injectors. for the price of a worthless ic i could build another setup just like mine for about a grand........
    i feel sorry for all you bastards that cant run e85 LOL!!
  9. #9 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    GT Level Member Hardonyomom's Avatar
    aurora
    Quote Originally Posted by 98GrandPrickVet View Post
    Every e85 post, I was just waiting for tyler to chime in lol.
    I have his build memorized by now
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  10. #10 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Cibolo, TX
    I see you listed both headers and a cam, you did read what darkhorizon posted and what I posted in response, right? Do you think e85 alone is going to make up for a cam, IC, AND headers? Also, lol @ ic's being worthless. Never spent a summer in south TX, huh?
  11. #11 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    May 2008
    Schuyler, NE
    A local guy ran e85 with 42.5lb injectors on a pretty much stock tune Regal with an intake and 3"DP. I believe he was running on a 3.2 pulley. Then, he used meth injection to run a 2.8.
  12. #12 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    And then, he put headers on it.
    Then sprayed it.
    And kept the stock trans. Then it turned into an '01 GTP.
    And it went 11.83 @ 116 <$2k in mods
  13. #13 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    May 2008
    Schuyler, NE
    LOL. No, he beat the piss out of that car, the trans started slipping, so he sold it. haha
  14. #14 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    GTP Level Member
    Jan 2015
    Lincoln, NE
    you talking about that idiot on scr busting the L67 myths?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  15. #15 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    May 2008
    Schuyler, NE
    Quote Originally Posted by NebTurboST5 View Post
    Yup
  16. #16 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Nov 2011
    NY
    Should consolidate all these E85 threads into a single grand unified theory!
    Next time I see E85 (thread) I'm just gonna pop some popcorn, kick back and giggle... Amuse myself!
  17. #17 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Apr 2013
    Flint, Mi
    Does anyone think that there might b more to gain to run 80lb injectors instead of the 42lb on stock tune thinking it might enable the use of a 3.0 pulley
  18. #18 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by revin24 View Post
    is this a real question?
  19. #19 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    Oct 2011
    Toledo, OH
    Nope, you imagined it.
    7"
  20. #20 Re: Stock motor, e85 how small of a pulley can be ran assuming custom tune
    May 2008
    Schuyler, NE
    You won't be able to run 80's on the stock tune.
  1. 3.4 pulley top swap and only seeing small boost
    By bfox507 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2014, 02:56 PM
  2. few new small mods. custom gauges!! led lights, hud fix.
    By colindunn in forum Visual/Body Modifications
    Last Post: 04-24-2014, 01:41 PM
  3. Small pulley and inter cooling
    By rolyat in forum General Tech Discussion
    Last Post: 09-05-2013, 08:22 AM
  4. Pulley Drop Vs Higher Timing (Custom Tune)
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 09:25 PM
  5. Custom phone mount in small console compartment
    By Dzebold in forum Visual/Body Modifications
    Last Post: 04-12-2011, 04:06 PM
