Thread: Need some advice on how I should Finnish my build
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 Need some advice on how I should Finnish my build
    GT Level Member revin24's Avatar
    Apr 2013
    Flint, Mi
    I want to stick to the SC but I'm not100% I have hand ported my heads the block needed to be bored . 02 over I personally love the sound of superchargers so I need a little help figuring this out I'm going to run 140lb Springs because eventually I want it to Rev past 7000 I want to run at the largest a 2.8 PULLEY non intercooled and I and that small Block idle sound so help me fill in the blanks here ppl
  2. #2 Re: Need some advice on how I should Finnish my build
    boom? you'll need a ic or e85 to pull that pulley off. 7000 rpm's? not much to offer up there.
    that great v8 sound, go buy a v8. you'l never get that out of a 3800.
  3. #3 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    Yes I'm going to run e85 for sure
  4. #4 Re: Need some advice on how I should Finnish my build
    I break stuff selliott's Avatar
    Kansas City
    You should definitely plan on e85. There arent to many running past that 7k mark to be honest i dont know that there is much benefit to it.
    Next question why are you boring? Are you going through the bottom end for some reason?
    Personally i would just buy a l26 block it would be cheaper than rebuilding it and it would give you slightly higher compression
    What compression pistons are you gonna use?
  5. #5 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    The motor had 250,000 on it and I bone head move tried driving thru some deep water when flint flooded to get to work and we'll drown the motor a couple months after that I thought that the car was pulling timing and discovered that I cracked both heads in the valve seat bridges so I decided to do a full rebuild and the cylinders were egg shaped the machine shop told me I needed to go a minimum on 20 over trust email I didn't want to
  6. #6 Re: Need some advice on how I should Finnish my build
    much cheaper too for a used block.
  7. #7 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    The block is already bored I just need to order the pistons next month
  8. #8 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    Keith black Silvo lite 8.5:1
  9. #9 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    I do want to run a gen v SC though but I haven't seen any lately need to run a bigger tb as well but don't know what I should run
  10. #10 Re: Need some advice on how I should Finnish my build
    Kansas City
    What rockers are you gonna use? Or how about this just post your build list. Then people can chime in. Also i hope you have a plan for a trans build.
    I run a northstar but there are lots of options for tb
    I have an extra genv but the rotor coating is trash, i just wanted the case for the hybrid build
  11. #11 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    There's not much more that is set in stone but 80#injectors and a e85 aem fuel pump I was going with stock rockers didn't think I really needed new ones
  12. #12 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    I definitely love the idle sound of the NIC also I figured the higher the rpms it would help overcome the valve lap of that can I do know that I cannot run more than 6300 rpm until I rebuild the trans
  13. #13 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    I take it those rotors are different than the gen 3 do u kno if there is a way to order replacement rotors
  14. #14 Re: Need some advice on how I should Finnish my build
    May 2008
    Schuyler, NE
    Stock rockers are best. You will probably need more octane than e85 has to offer for pulleys that small without an intercooler, unless the e85 in your area is over 85%.
    You are going to have a hell of a time with this build. Get a junkyard motor, put a cam in it, slap on an intercooler, feed it with e85, and you'll have a mid 12 second car on street tires all day long.
  15. #15 Re: Need some advice on how I should Finnish my build
    Kansas City
    Here is the is3 idle
  16. #16 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    Y that idle will due nicely what rpm is that idling at and e85 is plentiful around me for sure there are a few gas stations in my area alone
  17. #17 Re: Need some advice on how I should Finnish my build
    Kansas City
    Its idling around 1200 rpm it was a little cold it normally is in 800-1000 range
  18. #18 Re: Need some advice on how I should Finnish my build
    don't over complicate this.
    let me remind you 330/400 was done with stock block, stock rockers, stock heads, stock tb.
    heads only need to be milled for the is3 cam and others of comparable size or bigger.
    pick a cam feed it some corn, use as much stock parts are you can enjoy the car.
    It kills me to see people having cars torn apart every other week.
    Ohh and look at it this way the more stuff you can get away with using stock parts on the engine saves money for the transmission..........
    Its not a question of if your going to need a transmission build but when/how soon!
  19. #19 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    OK do u think it will idle any lower the lopier the idle the happier I will b lol I just gotta have that old school idle especially if it might sound better than my dad's corvette lol
  20. #20 Re: Need some advice on how I should Finnish my build
    Kansas City
    Honestly i wouldnt want it any "lopier" it has a nice idle without surging to much except at start up.
    The bad news is you cant beat a nasty v8 for sound
  1. Advice on new Regal Build
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2014, 02:56 PM
  2. Build Advice
    By TskiGTP in forum General Tech Discussion
    Last Post: 04-14-2012, 01:13 PM
  3. looking for build advice asap
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 11:52 PM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Turbo build advice: GTP and GS mating..
    By LowlyfeGTP in forum Turbo
    Last Post: 05-27-2008, 11:29 AM
