Thread: Need some advice on how I should Finnish my build
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: Need some advice on how I should Finnish my build
    GT Level Member revin24's Avatar
    Apr 2013
    Flint, Mi
    I guess I'm on my own then
  2. #42 Re: Need some advice on how I should Finnish my build
    On your own for what?
    When you want to do a trans.. that's reasonable enough to do. I built one, kinda. I say kinda because you want the valve body/channel plate to be done by TEP. The tools to do the upgrades and the extras that are done are beyond worth it. After that.. you only need a couple of specialized tools and even more knowledge from reading til your eyes bleed. It's worthwhile to read everything you can find. Learn the flow, understand how things work and apply etc, that'll set you up to do a much better job and simply following the book. Learn about spacer plate feed holes and clutch stacking/clearnancing. Look up a thread titled something like trans info by me. Some stuff is in there.
    Also.. 7000 rpm, cruise over to 3800Pro and read up on oiling deficiencies by Turbocharged400SBC
  3. #43 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    How long did it take u to build yours. I don't plan on ever running anything other than a school the valves I'm planning on putting in says do not use with turbocharged set ups but other than that I feel like there's a whole lot of loose ends that need to b taken care of like who will program the pcm or who can teach me to do it myself u kno stuff like that
  4. #44 Re: Need some advice on how I should Finnish my build
    I break stuff selliott's Avatar
    Kansas City
    Quote Originally Posted by revin24 View Post
    But for damn sure I'm going to crank the hell out of it and I have already a bunch of gauge to put in it I have 3 aero force, oil press, fuel press, boost/vac, air, and trans temp
    with the aeroforce you don't need gauges for Trans temp and oil pressure not sure till mine shows up but I think aeroforce will read all of those so all you would need is the 3 aeroforce gauges
  5. #45 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    I don't believe the oil sensor has more than one wire
  6. #46 Re: Need some advice on how I should Finnish my build
    Kansas City
    ? It has one wire I guess I'm not understanding the question. I just talked to intense yesterday and John told me the I could eliminate my oil gauge by using the aeroforce aux input
  7. #47 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    Yes u can but u still need to put in another sensor
  8. #48 Re: Need some advice on how I should Finnish my build
    you cant use the stock oil pressure sensor, its a 5 psi warning, and when it warns you its to late already.
  9. #49 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    I bought tinted glowshift gauges although I'm not sure weather or not the glowshift afr gauge will b accurate enough dose anyone happen to know if they are
  10. #50 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    And 5psi is way too late shouldn't it b something like 15-20psi
  11. #51 Re: Need some advice on how I should Finnish my build
    Topeka, KS
    Well that's nice mine has blinked for the last month until I changed my oil. Put a new sensor in, 4qt of Castrol 10w40 and 1qt of Lucus stop leak. Haven't had the light come back on but the oil plug had a good amount of shavings on it.
    Sent from my QTAQZ3 using Tapatalk
  12. #52 Re: Need some advice on how I should Finnish my build
    Topeka, KS
    I'm going to be doing a motor swap soon.
  13. #53 Re: Need some advice on how I should Finnish my build
    Apr 2013
    Flint, Mi
    Uuuummmm ya kinda sounds like that is in ur future
  1. Advice on new Regal Build
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2014, 02:56 PM
  2. Build Advice
    By TskiGTP in forum General Tech Discussion
    Last Post: 04-14-2012, 01:13 PM
  3. looking for build advice asap
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 11:52 PM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Turbo build advice: GTP and GS mating..
    By LowlyfeGTP in forum Turbo
    Last Post: 05-27-2008, 11:29 AM
