any info on replacing rocker panels on 1997 gtp. what did you use and any info on how you did it.
thanks Joe
thanks Joe
You can either buy the replacement panels they sell and cut out the rust and patch yours in or make your own panels to weld into place.
Either way you must cut the rust out, clean everything and then weld the new metal into place.
I didn't weld mine on my 97. I cut out the rust and riveted them in. I used bed liner spray on the inside and outside of the rockers and it held really well. Just had to touch up the back parts near the rear tires.
http://www.autobody101.com/forums/viewtopic.php?t=13467
That's an extreme case but a very good thread with pictures of how to properly do it!
Also if you dig through ITHURTZ members ride thread im sure you can see what he did to fix his.
I cant think of any other threads at the moment but more are out there.
Google grand prix rocker replacement and click images and youll find much more info.
thanks for the info
