Thread: Hot air always coming into the cabin from behind the center console?
Results 1 to 4 of 4
  1. #1 Hot air always coming into the cabin from behind the center console?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    '99 GTP
    At the bottom near the footwell, pretty much right behind the stereo. It starts coming in as soon as the engine warms up.
    Does anybody know what the problem might be and how I could fix it? It's tolerable for now but, being in AZ, it won't be once summer arrives.
  2. #2 Re: Hot air always coming into the cabin from behind the center console?
    I want to say blend door
  3. #3 Re: Hot air always coming into the cabin from behind the center console?
    sounds like the floor is staying open when the heat is off. turn it to cold, see if the air is cold or hot.
    also make sure air is coming from only where it should when you control it. only def, vent or floor. i know you can mix the air flow, so if its mixed when not being told to be mixed something is hanging up.
  4. #4 Re: Hot air always coming into the cabin from behind the center console?
    Sep 2014
    St. Paul, MN
    Sorry for the delayed response.
    If I run cold air, I get cold everywhere. So it only seems to put out hot air when the system isn't on at all.
  1. Center Console
    By Mcbride in forum Visual/Body Modifications
    Last Post: 01-28-2013, 05:08 PM
  2. VERY LOUD noise coming from inside the cabin
    By Fox in forum General Tech Discussion
    Last Post: 05-17-2012, 10:16 AM
  3. center console
    By kjohnson in forum Visual/Body Modifications
    Last Post: 12-06-2009, 06:51 PM
