Thread: Need quick help.
Results 1 to 18 of 18
  1. #1 Need quick help.
    Dec 2010
    DMV
    Ok I'm looking to find out how I can remove my power seat. Motor is acting funny and I wanna change it but if course it only moves up enough for me not to reach the bolts to remove it lol.
    Any ideas? Wanna get this done tomorrow if possible
    Edit. Moves back just fine. Just not all the way forward
  2. #2 Re: Need quick help.
    GTP Level Member buickman104's Avatar
    NYC
    Two bolts in the back of the seat. I think they are 15mm. Then the front of the seat is held in with two J shaped brackets so you push the seat forward to lift to free the seat.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: Need quick help.
    Dec 2010
    DMV
    See the issue is that I can't reach the bolts lol. The seats don't move up enough for me to. Access to the bolts
  4. #4 Re: Need quick help.
    Take a look at how the hose hooks onto the evap switch under your hood or refer to a post about doing a fuel pump. The oval clip that needs to be squeezed into a circle to come off is what I'm referring to.
    That oval clip that gets squeezed is how the drive shafts under the seats are held in place. If you find the correct one and unhook it.. you can then use a drill to drive the shaft and move the seat forward. However..I have ... successfully removed seats in a JY w/o power and while the bolts were tough to get at. Ratcheting wrench with pivoting head is all you need.
  5. #5 Re: Need quick help.
    Dec 2010
    DMV
    Ok thanks Bill gonna take a look now. Do I insert the drill into the oval clip?
  6. #6 Re: Need quick help.
    Nah..when you pull the end by the motor, it'll have a square shaft sticking out. Put your drill on that and hit go
  7. #7 Re: Need quick help.
    Mar 2012
    NC
    Since I like to do things different, if I have a power seat issue like that, I take the seat off of the seat base then I have tons of room to access the two rear bolts from the top. Takes about the same amount of time IMO too.
  8. #8 Re: Need quick help.
    Dec 2010
    DMV
    Awesome thanks Bill
  9. #9 Re: Need quick help.
    Dec 2010
    DMV
    How to remove the seat base? It's a heated power seat
  10. #10 Re: Need quick help.
    Mar 2012
    NC
    4 13mm bolts. Remove lower seat trim, gives plenty of access to the D/S front bolt, then there a P/S front bolt and two in the back. That allows you to flip the seat forward and go almost straight down on the two bolts that hold the frame to the car.
  11. #11 Re: Need quick help.
    Dec 2010
    DMV
    You and me until the abbreviations lol.
  12. #12 Re: Need quick help.
    FWIW there is room without going forward on the seat to remove the bolts. The trouble is getting to them. Hence the ratcheting wrench.
  13. #13 Re: Need quick help.
    Dec 2010
    DMV
    Ok bill thanks again.
  14. #14 Re: Need quick help.
    SE Level Member jimzssei's Avatar
    Sep 2014
    Ratcheting wrench, Bill beat me to it. One of the better ideas tool makers came up with :beer:
  15. #15 Re: Need quick help.
    Dec 2010
    DMV
    Ok found which one is acting crazy, it jerks once it hits the limit that it reaches. So my options are the bolt remove or just turn the shaft until it moves up enough
  16. #16 Re: Need quick help.
    I'm not sure if you need a motor, are having shaft issues or if there's a track problem.
  17. #17 Re: Need quick help.
    Sep 2014
    ... are having shaft issues... .
    That's what she said. Sorry, had too
    You never know what you'll find under a car seat. I recently and successfully got a power seat working again by removing several pounds of animal hair off of every mechanism under the seat, and lubing up all the moving parts.
    The car smelled better afterwards too
  18. #18 Re: Need quick help.
    Dec 2010
    DMV
    Lol. Im going to take a look at it when I get to work. Thanks guys
  1. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  2. Quick DIC ?
    By blueGT00 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2011, 01:26 PM
  3. take a quick second...
    By kuntzie in forum Off Topic Discussion
    Last Post: 05-21-2010, 05:33 PM
  4. I need help quick!
    By shape275 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 03:57 PM
  5. Just a quick Q
    By 1998xGTP in forum Forum Bugs/Suggestions
    Last Post: 03-30-2009, 02:12 PM
