Thread: How long for OBD to be ready after clearing codes?
Results 1 to 15 of 15
  1. #1 How long for OBD to be ready after clearing codes?
    Naperville, IL
    I am looking for some guidance. In Sept. my daughters '06 Grand Prix base had the check engine light on. Since DIC said check gas cap I took a new GM gas cap with me on the next visit. Car had DTC P0455 stored and pending. I replaced the gas cap and cleared the code doubting that would do it. The check engine light came back on. I drove back down (she is at college 140 mi away) on Sept. 20, the car had DTC P0455 again. I replaced the purge canister and solenoid (AC Delco parts 20941985 and 19257603). I then cleared the code and everything has been good. She has only driven home once since then so the car only has about 350 miles on it since then and I have no idea on how many ignition cycles. When we went for IL emissions test the car failed as the OBD was not ready yet, this was after ~3 weeks. After 7 weeks my Innova 31703 scanner still shows the CAT and EVA systems as flashing so the yellow light is lit indicating the system is not ready for test yet. There are no DTCs pending or stored. Does anyone know how many miles or ignition cycles that are needed to get these OBD systems to show "Ready". I would really like to have the emissions test done when she is home for Thanksgiving as the registration needs renewal in December and I have to pass the test first.
    Thanks in advance for your time.
  2. #2 Re: How long for OBD to be ready after clearing codes?
    my evap can take forever to be ready too. you should pass with one system not ready.
  3. #3 Re: How long for OBD to be ready after clearing codes?
    Naperville, IL
    @Scottydoggs - not in IL..... you don't need to have a code stored or pending. If any system is not ready you fail. If you fail twice you need to bring in receipt from certified mechanic... I don't want to fail a second time and worry about it.
  4. #4 Re: How long for OBD to be ready after clearing codes?
    damn that blows.
    try un hooking the battery for 30 minutes, this will reset the pcm. and then your re starting all the system checks.
    evap from what ive read about it only does its test as the tank drops past the 1/2 way point. so maybe letting it drop to a quarter tank, then filling it up justr past 1/2 way will aid in speeding up the readyness.
    or if you have some one local with a tuner they can delete the code and it will never set that code again, and the systyem shows ready.
    i have my egr, evap, no cat and rear o2 deleted this way. all systems show ready.
  5. #5 Re: How long for OBD to be ready after clearing codes?
  6. #6 Re: How long for OBD to be ready after clearing codes?
    Naperville, IL
    @Scottydoggs - I don't think pulling the battery will do it as the emissions check also wants to very how long since a reset or clearing of codes.
    @billboost37 - thanks I will have to run through the cycle when she comes home. After driving home 140 miles x two and all her local trips the only one that I can see not being done is a casual deceleration without touching the brake.
  7. #7 Re: How long for OBD to be ready after clearing codes?
    I've had to try and meet all, sometimes it's difficult. Best of luck.
  8. #8 Re: How long for OBD to be ready after clearing codes?
    Quote Originally Posted by emamon View Post
    if bills links dont work out. its a waiting game. my evap was incomplete for a month once.
  9. #9 Re: How long for OBD to be ready after clearing codes?
    There's certain things that have to be met. I think at one time I posted the older set of how to get them all.
  10. #10 Re: How long for OBD to be ready after clearing codes?
    id like to know how they can see how long ago the codes were cleared. that dont make sense to me at all.
    cel off, systems ready, it should just be a pass. no questions asked.
  11. #11 Re: How long for OBD to be ready after clearing codes?
    That's the thing.. if the systems aren't ready.. it fails
  12. #12 Re: How long for OBD to be ready after clearing codes?
    Naperville, IL
    After 2 months and 950 miles the Cat and Evap still not ready. Had to take it to dealer for keyhole plugs so have them looking at it. They say the conditions indicated a P0442 (small evap leak) should be setting but is not. They are diagnosing, will post what they find. Then a RR wheel hub once it gets back home.
  13. #13 Re: How long for OBD to be ready after clearing codes?
    Nov 2013
    Central VA
    sorry for thread hijack OP, but I would like to ask BillBoost37 if he knows why the Autotap software is no longer available for sale. I have it and a couple years ago used it to help my brother with one if his cars, he went to go purchase and it was no longer for sale. Did a competitor buy them out and kill it off or something? Just wondering if you might know.
  14. #14 Re: How long for OBD to be ready after clearing codes?
    Quote Originally Posted by wb22rules View Post
    if you dont want to thread jack PM him. your question has 100% nothing to do with this thread.
  15. #15 Re: How long for OBD to be ready after clearing codes?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Google search "GM drive cycle" . The vehicle needs to complete and pass two full drive cycles without fault after codes have been cleared to become "ready"
    There is a list of things to do and way to drive to help your vehicle complete the two full drive cycles quicker.
  1. Clearing out my stash
    By 91parkave in forum For Sale - Parts
    Last Post: 10-16-2013, 09:40 PM
  2. Replies: 2
    Last Post: 06-23-2013, 08:11 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. MAF Test and Clearing Codes
    By gobux in forum General Tech Discussion
    Last Post: 06-10-2011, 09:16 PM
  5. clearing it up
    By jcmonteman in forum Forum Bugs/Suggestions
    Last Post: 06-06-2011, 11:36 PM
