Thread: What oil filter should I use
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 83
  1. #21 Re: What oil filter should I use
    My requirements are metal end caps, and a silicone anti-drainback valve. Of course a good filter element comes with those options. You can see if a filter has metal end caps by looking inside the center hole, and the anti-drainback valve can be seen through the small holes around the center hole. If it's black it's plain rubber which isnt as flexible and prone to hardening from heat and just time.
    So what filter should I buy?
    This is what my filter looks like:
  2. #22 Re: What oil filter should I use
    Dec 2012
    Where 4T65E's were born
    Haha idk, I haven't looked into the cartridge oil filters. The anti-drainback valve is in the adapter or oil passages, and I'm not sure if metal end caps are an option. Those are plastic, and the paper style is the only other I've seen. Still, I've seen the plastic ones fall apart before. Edit: I have seen metal over plastic caps, for whatever reason.
    Sold.
  3. #23 Re: What oil filter should I use
    St. Louis
    I've run the Wix filter (51040) on my 00 GPGT since I dropped in the used motor that had 150K~ish miles on it and have had 0 issues. Now sitting at 334K miles and counting. I change it every 3K miles and run regular dino oil. Run the same filter on my 95 Bonneville SE as well with no issues. I run Wix on all my cars except my 03 Vic.
    I've run Fram filter before on my SBF motors and had issues with them. I watched my oil pressure gauge drop to 0 multiple times and heard the valvetrain clatter and as soon as I changed the filter to a Wix I never had an issue again. Not sure what happened but I wasn't willing to bet my engine on it. I just don't run Fram oil filters anymore. Just my personal opinion though before this turns into a sh*tstorm lol...
  4. #24 Re: What oil filter should I use
    GT Level Member K Slice's Avatar
    Jul 2013
    Traverse City MI
    Always used Puralator or Bosch, made by the same company last I checked. Both are good quality and inexpensive, usually included in the deals from advance or AZ. Basically with filters you get what you pay for. A high grade Fram will be just as good as a Wix. Just don't go crazy and put down a bunch on something like a Mobil 1 or k&n which are just selling you their name.
  5. #25 Re: What oil filter should I use
    HUDSON
    I use new Oriley's brand filter, They are also made by WIX. MGL51040
  6. #26 Re: What oil filter should I use
    Enfield, CT
    Quote Originally Posted by K Slice View Post
    Bosch, Mobil 1, K&N are made by Champion Labs. Same Junk.
    Purolator is owned by a different company.
  7. #27 Re: What oil filter should I use
    Mar 2012
    NC
    I've always had good luck with the Purolator Pure One...awesome filtration and construction...never had a failure...and I cut my filters open after each oil change.
  8. #28 Re: What oil filter should I use
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Use the filter for a 99 gmc jimmy. It is the same in every single way except its just longer and therefor has more filter area. Fits great. I have been running them for 3 years now with no issues. Since its taller it gives you more room to grip it and take it off as well. Brand is up in the air as you can see from previous responses but WIX is my personal favorite. Reasonable price and good quality.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #29 Re: What oil filter should I use
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    yep I do this ^^ 4wd jimmy filter works great.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  10. #30 Re: What oil filter should I use
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by HighOctaneRacing View Post
    Seriously?
    I don't believe this is possible. If someone hasn't heard of WIX, then perhaps they should consider paying someone to change the said filter.
  11. #31 Re: What oil filter should I use
    Apr 2012
    Goderich, Ontario
    I always use Napa gold (#1040)
    -Paul Walker
  12. #32 Re: What oil filter should I use
    Arizona
    If you change your oil enough it won't natter what off the shelf filter your using.
  13. #33 Re: What oil filter should I use
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    wix
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  14. #34 Re: What oil filter should I use
    Dec 2008
    Lawndale, CA
  15. #35 Re: What oil filter should I use
    SE Level Member seafordchristian's Avatar
    Oct 2014
    Does anyone know how to make my gp a bit faster
  16. #36 Re: What oil filter should I use
    Sep 2014
    Grand Rapids, MI
    NOS bro, lots of NOS
  17. #37 Re: What oil filter should I use
    Oct 2014
    Not that fast
  18. #38 Re: What oil filter should I use
    Push it down a hill
    04 Comp G.
  19. #39 Re: What oil filter should I use
    Oct 2014
    You should go do that .
  20. #40 Re: What oil filter should I use
    Oct 2014
    How about a chip
  1. where's my gas filter?
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2011, 11:22 PM
  2. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
