Thread: Engine movement
Results 1 to 17 of 17
  1. #1 Re: Engine movement
    Solution = stop going in reverse.
    I get a clunk or knock or something if I hit the pedal hard enough in reverse. I figure it's my headers hitting or everything shifting at once in the front end. I have new struts/mounts and new lca's and I just stopped caring.
  2. #2 Re: Engine movement
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    As mentioned above. My 3 bolt flange on my collector has one of the ears at 12 o'clock. Every time I hit the gas in reverse, that flange hits the bottom of the floor tunnel.
    Official GPF Red Neck
  3. #3 Re: Engine movement
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Makes me glad to know other guys have this problem. I thought my problem was severe, but that sounds just like my issue. Only under heavy enough throttle in reverse do I get this weird noise.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Engine movement
    Feb 2013
    Missouri
    Quote Originally Posted by ILoveGM View Post
    Same here. I was wondering if it was the ABS self test or something.
  1. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  2. Noise on first movement of car and when braking on slick surface
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 02-01-2012, 11:21 PM
  3. cv shaft and joint movement
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-24-2011, 09:16 AM
  4. Grinding noise in reverse, then no movement
    By chantspel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2010, 08:08 AM
  5. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
