Thread: Sunroof
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 159
  1. #1 Sunroof
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    My sunroof on my 98 gtp seems to not be shutting properly, when it closes the passenger side rear corner do sent pop up in place, I have to push it up on that corner and if I push to hard it will come up and I can see outside through a crack, anybody else?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  2. #2 Re: Sunroof
    Yoga city
    have you tried to adjust that side? there is a couple screw that can be moved slighty to help remedy that.
  3. #3 Re: Sunroof
    Jul 2010
    Didn't know there was one, is it a star head?
  4. #4 Re: Sunroof
    Jul 2010
    I found a star head screw laying in the track
  5. #5 Re: Sunroof
    find its home now.
  6. #6 Re: Sunroof
    Nov 2010
    Baltimore
    I don't know the answer to your problem, but if you ever decide to replace it take it from someone who has done it...it's extremely easy! A few bolts here; a few there; unplug it. The reverse when installing the good one and you're done. I give it 45 minutes..1 hour tops. Of course you have to take the headliner down partially not all the way off, but that's included in the time it would take to replace it.
  7. #7 Re: Sunroof
    Jul 2010
    It got dark scottydoggs and couldn't see but CBWhite so no silicone?
  8. #8 Re: Sunroof
    Nov 2010
    Baltimore
    What do you mean no silicone?
  9. #9 Re: Sunroof
    Quote Originally Posted by 94grandprix View Post
    look for a hole, or a screw on the other side that would match the side you found the screw.
  10. #10 Re: Sunroof
    Quote Originally Posted by CBWhite View Post
    I think he was wondering if it gets glued in like a windshield..
    And as far as I know the rubber seal is what seals the sunroof in.
  11. #11 Re: Sunroof
    Jul 2010
    Ya that's what I meant like a windshield,and scottydoggs I will when it doesn't rain
  12. #12 Re: Sunroof
    Nov 2010
    Baltimore
    No... it's all one assembly. Like i stated before it's easy to do. If you're gonna do it and have any questions just let me know.
  13. #13 Re: Sunroof
    Jul 2010
    Ok I'll update when I find out something and can I just pull the Grey cover out, the one that covers the sunroof cause it's loose and binds the sunroof or would that require taking the sunroof out?
  14. #14 Re: Sunroof
    Jul 2010
    *headliner not sunroof
  15. #15 Re: Sunroof
    if you have a slider that covers the sun roof, it should come down with the headliner.
  16. #16 Re: Sunroof
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    the slider is part of the sunroof assembly.The only thing that you would have to remove from that area to get the headliner down would be the trim ring
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  17. #17 Re: Sunroof
    Jul 2010
    I'm saying the slider thing isn't any good anymore can I just pull it out without taking the headliner down
  18. #18 Re: Sunroof
    redneck tennessee
    There are four torx head screws that attach the actual glass to the arms that move.Its one of those most likely.If that is not causing the issue,it could be that the cable on one side has jumped a tooth on the motor.That makes one side have more pull than the other and cause it to open and close unevenly.When it closes it wont lock on that side and will stay popped up a little.
  19. #19 Re: Sunroof
    redneck tennessee
    Im not shure if you can remove that or not.Its a 98, so it has a two piece sunshield right?
  20. #20 Re: Sunroof
    Jan 2014
    AR
    The answer to that is no. You would need the sunroof regulator assembly out for that, and you almost have to break that slider to separate it from the regulator. I have one car where the slider slides around like crazy, another that gets stuck, and another thats just right but the regulator is bad, go figure. Your trouble may just be the screw that fell out needing to be put back.
  1. Can anyone with a 99-03 GP with a sunroof...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 03-02-2010, 02:11 PM
  2. Is Sunroof the same 97-03?
    By Tfreeds in forum General Tech Discussion
    Last Post: 02-14-2010, 03:22 PM
  3. Sunroof
    By 1LoudGrandPrix in forum Visual/Body Modifications
    Last Post: 10-11-2009, 07:37 AM
  4. Sunroof?
    By mike171562 in forum General Tech Discussion
    Last Post: 08-26-2009, 12:21 PM
  5. Sunroof...
    By SlowM90 in forum General Tech Discussion
    Last Post: 07-28-2009, 04:57 AM
