Thread: Heater motor only works on high then kicks off.
Results 1 to 13 of 13
  1. #1 Heater motor only works on high then kicks off.
    Sep 2014
    ohio
    Heater motor only works on high then kicks off. Headlights do the same thing. Is it a easy fix?
  2. #2 Re: Heater motor only works on high then kicks off.
    St. Louis
    What year car are we dealing with?
  3. #3 Re: Heater motor only works on high then kicks off.
    Sep 2014
    ohio
    2001 gt. Every thing ive been reading points to the ignition switch
  4. #4 Re: Heater motor only works on high then kicks off.
    I'd say ignition switch too.
    My sisters 02 GT has this same problem. I swapped blower motors with my car and still did it, I bought a new blower motor resistor and helped but it still will either work on all settings, just on high or it will just stop working altogether. Sometimes it will work on 5 if you turn the car on and it's there but as soon as you go down to 4 is shuts off and if you switch back to 5 it wont work again.
    Next set is the ignition swap as that is the whole thing controlling power to it, the part is not to much. Rockauto has a brand new AC DELCO units for 75 bucks I think.
    How to remove it and swap new in.
    http://www.sparkys-answers.com/2009/...-changing.html
  5. #5 Re: Heater motor only works on high then kicks off.
    Sep 2014
    ohio
    I ordered a new ignition switch today. I am also replacing the rack and pinion now.
  6. #6 Re: Heater motor only works on high then kicks off.
    Nov 2011
    Bala ON.
    I just finished taking my heater blower motor out yesterday and there was no signs of wear, I was about to call my service guy then I read your post. I rushed outside re-installed the blower motor, giggled the ignition key and abracadabra my blower is working. Thanks guys, you just saved me my rent money.
  7. #7 Re: Heater motor only works on high then kicks off.
    Sep 2014
    ohio
    Quote Originally Posted by Balabill View Post
    It ended up being the ignition switch. Working great now.
  8. #8 Re: Heater motor only works on high then kicks off.
    Nov 2011
    Bala ON.
    FALSE ALARM, Looks like I will be taking my Gran Prix in for service to fix the problem.
  9. #9 Re: Heater motor only works on high then kicks off.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Another give away is if your auto headlights shut off at the same time as the blower motor. Whenever my blower motor would kick off the auto headlights turned off as well. Switched to a junkyard ignition switch and all is well now. If I had a schematic I could show you what fuse to probe to see if its the ignition switch dropping out.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  10. #10 Re: Heater motor only works on high then kicks off.
    Grand Rapids, MI
    Quote Originally Posted by sschevelle View Post
    well that's promising. I seem to be having the same issue and although I know the resistor is bad, I should at least have #5 heat (if I am correct). my symptoms match yours to a tee.
    how was the job?
    Quote Originally Posted by Frosty View Post
    interesting...however I am not finding this to be the case. auto lights are working fine but no blower.
  11. #11 Re: Heater motor only works on high then kicks off.
    Sep 2014
    ohio
    The job of replacing the ignition switch only took about an hour. Just having the right tools helps alot
  12. #12 Re: Heater motor only works on high then kicks off.
    Grand Rapids, MI
    Right. Well I did some testing with the resistor last night and when the dial is turned to number 5, I have power all the way up to the resistor. Probably just gonna replace it and go from there.
  13. #13 Re: Heater motor only works on high then kicks off.
    Apr 2011
    South Dakota
    They go bad anyways. Replace the resistor and if its still broke you know what to try next.
    I love Decker<3
  1. Replies: 8
    Last Post: 05-17-2016, 06:24 PM
  2. Blower motor only works on high.
    By 99gpse in forum General Tech Discussion
    Last Post: 04-15-2012, 12:08 PM
  3. Is this how the heater core works?
    By TeacherCreature in forum General Tech Discussion
    Last Post: 10-06-2011, 06:28 PM
  4. Get this. I have no heat, heater core works fine.
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2011, 09:15 AM
  5. AC / Heater Blower Fan only works on one speed.
    By FormulaW66 in forum General Tech Discussion
    Last Post: 05-24-2011, 05:42 PM
