Thread: 01-03 Steering Wheel into a 2000
Results 1 to 5 of 5
  1. #1 01-03 Steering Wheel into a 2000
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Hey guys, I used the search function and scrolled through over a dozen topics on this same question. None ever came to a conclusion.
    I want to take an 01+ wheel as seen below:
    And swap it into my 2000. It seems a lot of people have wondered about doing this, but I cant find any concrete evidence on it working.
    Would the clock springs be the same? Is it a case of simply uninstalling and swapping over? I cant see a lot changing in one model year.
    Any and all input would be greatly appreciated. I cant stand the 2000 wheel.
    01-03 Steering Wheel into a 2000 Attached Images
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  2. #2 Re: 01-03 Steering Wheel into a 2000
    May 2013
    RI
    I haven't personally done it, but from what I have read you need to either use the 01+ upper steering shaft or swap the column (probably the easiest). The 01+ steering wheel has a different number of splines. Here's a guy that did it to his TA:
    http://ls1tech.com/forums/13036991-post94.html
    I think this is the part #:
    http://ls1tech.com/forums/17187885-post105.html
    Here is the newer style shaft:
    http://ls1tech.com/forums/17186845-post100.html
  3. #3 Re: 01-03 Steering Wheel into a 2000
    Nov 2011
    Omaha, NE
    I actually looked mostly for 97-00 grand prixs because I can't stand the newer style wheel lol
  4. #4 Re: 01-03 Steering Wheel into a 2000
    Jun 2010
    Edmonton
    That seems like a bunch of work just to have a grand prix wheel. I would do it if it was a simple swap of the wheels.
    I'll leave it alone. Why bother risking it.
    Thanks guys.
  5. #5 Re: 01-03 Steering Wheel into a 2000
    GTP Level Member buickman104's Avatar
    NYC
    That steering wheel also came in the 2000+ Bonneville. From having access to my 2000 gtp and a 2000 ssei i prefer the feel of my 2000 gtp steering wheel. if feels softer and gripier than the newer steering wheel. yes, it does have more modern button design and lay out but overall the newer design steering wheel feels cheaper to me.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. steering wheel
    By jman44 in forum Introductions/Noob Questions
    Last Post: 10-03-2013, 12:11 PM
