Thread: heater core woes
Results 1 to 11 of 11
  1. #1 heater core woes
    May 2011
    winnipeg
    What is the best way to backflush an aluminum heater core, and should I use a flush chemical or just water? Switch to PEAK or stay with dex cool
  2. #2 Re: heater core woes
    to flush it just take both heater core hoses off the alt bracket, then put a garden hose to one hose and flush it. flush from the other hose too if the waters not flowing out as fast as it going in. dont use a sprary end, just open hose to hose. light med pressure.
  3. #3 Re: heater core woes
    Feb 2013
    Woodbridge NJ
    Remove the two hoses from the bracket as Scotty stated. Flush with your hose in both directions. I use one of these http://www.grainger.com/product/Fire...set&s_pp=false. The tip fits perfectly inside the hose so you can turn on the water to whatever pressure you would like with the nozzle already in the hose. Works perfectly
    Don
    2004 GT1
  4. #4 Re: heater core woes
    To much pressure can blow the core up, be careful
  5. #5 Re: heater core woes
    Oct 2011
    Toledo, OH
    Take both hoses off and only flush from the outlet of the core, not the inlet side. Not with high pressure either. Leave enough space between the garden hose and heater house to let the extra water overflow until it flows freely. You aren't trying to blast the clog out, just loosen it and let it flow out backwards.
    7"
  6. #6 Re: heater core woes
    GT Level Member kyliek23's Avatar
    Feb 2013
    My heater core cracked from doing this be very careful. New GM one costs like $100 ish on rock Auto.
    2005 Pontiac Grand Prix
    2005 Pontiac Grand Prix Base
  7. #7 Re: heater core woes
    Feb 2013
    37.295091, -121.930053
    you paided $100 bucks for your heater core? i got mine for 55 plus tax
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: heater core woes
    Feb 2013
    Wth. Where at?
  9. #9 Re: heater core woes
    Oct 2011
    Toledo, OH
    Quote Originally Posted by kyliek23 View Post
    You did it wrong. Too much pressure, wrong direction etc.
    7"
  10. #10 Re: heater core woes
    Feb 2013
    My fiancé did it when I was gone with my dad. So I was pretty upset.
  11. #11 Re: heater core woes
    Feb 2013
    Wth. Where at?
    i got it from here
    http://tinyurl.com/knfsqek
  1. heater core
    By dlk in forum General Grand Prix Discussion
    Last Post: 04-22-2014, 06:29 PM
  2. heater core
    By jase711 in forum Introductions/Noob Questions
    Last Post: 02-18-2013, 12:22 PM
  3. heater core
    By pontiaclemon in forum General Tech Discussion
    Last Post: 07-11-2012, 12:00 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. heater core?
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2009, 02:16 PM
