Thread: 2003 Impala base trans issue?
Results 1 to 2 of 2
  1. #1 2003 Impala base trans issue?
    Feb 2013
    Woodbridge NJ
    So the '03 Impala is having issues. I am not the primary driver so I have only some knowledge about the issue. My son has told me about it and I have felt it on limited driving. So the car, when running and in gear, is super sluggish. Let me explain. When at a stop sign or light and you let off the brake to begin moving the car will just sit there. It will not move until the throttle is pressed. Also when the trans is cold it will jolt before moving from a stop. He also told me of another issue that I did not feel when I was driving it. He said that when he climbs a slight incline and keeps the throttle position constant he is getting some bucking/stuttering.
    My old school knowledge points me at the torque convertor. But I know with all the sensors and wiring that cars have nowadays that it can be almost anything. I forgot to mention that I drained and refilled the trans with Dexron VI this past weekend since the car is 11 years old and has 116,000 miles on it. I do believe that the trans fluid was still factory fill. Son says fluid change had negligible results.
    Anybody that can point me to a starting point? I am hoping that this issue has happened to somebody before and that an easy repair took care of it. thanks in advance folks
    Don
    2004 GT1
  2. #2 Re: 2003 Impala base trans issue?
    The bang start is likely a worn input piston piece, rebuild kits have longer seals and that piece is nearly an automatic replace in these transmissions.
    The sluggish could be seals leaking etc. For some odd reason impala owners report more symptoms like this. Not sure why, maybe something in the programming makes it easier to feel/notice.
  1. What trans can go into a 2008 grand prix base model?
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-21-2014, 08:52 PM
  2. 02 Impala steering issue
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2013, 06:45 AM
  3. 2007 Base overheating Issue
    By bdkruse in forum Introductions/Noob Questions
    Last Post: 02-04-2013, 10:10 AM
  4. 05 Impala LS VS Late 70's camaro/firebird/trans am
    By Grimsin in forum Track Sessions and Kills
    Last Post: 07-16-2011, 05:45 AM
  5. old 2003 impala
    By nicks98gtp in forum Members Rides
    Last Post: 03-15-2011, 05:31 AM
