Thread: p0171 showing after removing injectors
Results 1 to 5 of 5
  1. #1 p0171 showing after removing injectors
    Mar 2014
    SE PA
    I recently removed the fuel rail/injectors to have some room to replace the dog bone bracket and after putting it all back together, I'm getting a CEL, code P0171. I did notice that the o-rings on the injectors were all chewed up. Otherwise I don't see what I'm doing wrong. There is also a hissing sound coming from the rear injectors
  2. #2 Re: p0171 showing after removing injectors
    go buy 6 new o rings for the lower part of the injectors, pull the rail again. with a razor cut the old ones off, then oil the new o ring and roll it on.
    get some brake cleaner and 50 Q tips. spray some brake cleaner in the cap so you have a puddle of it, dip the q tips in the cleaner and then clean out the injector holes.
    now re oil or use Vaseline to re lube the o rings and slide them back in the holes.
  3. #3 Re: p0171 showing after removing injectors
    Mar 2014
    SE PA
    Thank you sir for the speedy reply!
  4. #4 Re: p0171 showing after removing injectors
    Mar 2014
    SE PA
    Just took your advice and put new oiled o-rings on and after clearing the code it no longer comes back. Not only that but my mpg shot up from ~16 to ~23!
  5. #5 Re: p0171 showing after removing injectors
    bad o rings is a bad vac leak. so yeah, your cars gonna feel better now. glad its all fixed up now.
  1. Showing off my new rims :D
    By LePrix in forum Tires & Wheels
    Last Post: 11-02-2011, 01:06 AM
  2. thought this pic was worth showing
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 12-22-2010, 08:35 PM
  3. DIC showing wrong date
    By 04CompG in forum General Tech Discussion
    Last Post: 12-03-2008, 02:21 PM
  4. Why is my signature not showing up?
    By Hayden in forum Forum Bugs/Suggestions
    Last Post: 09-16-2008, 01:36 PM
