Thread: Dash removal
Results 1 to 17 of 17
  1. #1 Dash removal
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Ok I posted here while back and I couldn't get a answer or find my post,my Grand Prixs dash has a bad place on it,I want to swap pads out but idk were to start,any help???
  2. #2 Re: Dash removal
    Jul 2010
    It's a 00
  3. #3 Re: Dash removal
    Jul 2013
    Phoenix
    Im in the same place. Where do you get a replacement pad in the first place? I would bet you'd have to start by pulling the instrument panel cover off, then remove every bolt you can find anywhere on the front end of the cab?!?
  4. #4 Re: Dash removal
    Jul 2010
    I think it comes out in pieces,scottydogs took one out I think but I couldn't get a answer from him,I'll be getting a donor car and if it has a good one in it ill take it out of it
  5. #5 Re: Dash removal
    It comes out as one piece. I did this not too long ago for my neighbor kid. Pull the cluster, trim panel, a pillars then unbolt what you find. Wiggle and you'll find the bolts you are missing.
  6. #6 Re: Dash removal
    Jul 2010
    Ok it was you I was thinking who did it,so the air bag dosent have to come out?
  7. #7 Re: Dash removal
    Feb 2010
    TN
    Quote Originally Posted by 94grandprix View Post
    What hasn't Bill done?
  8. #8 Re: Dash removal
    Nov 2011
    NY
    Quote Originally Posted by Logan541 View Post
    Lol... True this!
  9. #9 Re: Dash removal
    bill posted a pic of the dash out, the steering column needed to be un bolted and lowered out of the way, and lots of wires need to be unhooked from what i saw in the pic.
  10. #10 Re: Dash removal
    Jul 2010
    What's the link?
  11. #11 Re: Dash removal
    i think it was in the "what did you do to your car today" thread. no write up involved, just the pic and look what i did type thing lol
  12. #12 Re: Dash removal
    Jul 2010
    Thanks
  13. #13 Re: Dash removal
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    you need a 7mm, and a 13, its not to bad at all, maybe an hour tops, air bag stays in.
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  14. #14 Re: Dash removal
    Jul 2010
    Ok thanks,that's one main thing I want done in my gp,besides a 3 inch whole in my carpet,my mat almost covers it up though
  15. #15 Re: Dash removal
    Jul 2010
    What's he mean by a pillars and it dosent seem like itd be Necessary to drop the column, he was just trying to find the burnt wire, plus I'm wanting to get a pad with a hud already cut out stock plus mines cracked and faded, so basically start but removing trim then speedo and glove compartment,then a few screws here and there then wiggle and does it have any clips?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  16. #16 Re: Dash removal
    Jan 2014
    AR
    A-pillars = vertical trim panels along the edges of the windshield. Goes from dash to headliner.
  17. #17 Re: Dash removal
    Jul 2010
    Ok sounds easy
  1. dash removal..
    By WayneG99 in forum 04+ Specifics
    Last Post: 11-27-2020, 11:23 AM
  2. 04+ Dash Removal
    By lambokit in forum 04+ Specifics
    Last Post: 09-14-2013, 09:52 AM
  3. 98 gtp dash removal
    By mscott9549 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 08:43 AM
  4. 97-03 Dash Removal
    By cboth686 in forum General Tech Discussion
    Last Post: 12-26-2008, 12:51 AM
  5. Dash Removal?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-21-2008, 05:58 PM
