Thread: What to look out for on GXP models?
Results 1 to 20 of 31
  1. #1 What to look out for on GXP models?
    May 2014
    ft worth
    Advice/Comments/ Things I should pay special attention to?
    Thanks in advance for any help!
  2. #2 Re: What to look out for on GXP models?
    GTP Level Member buickman104's Avatar
    NYC
    Pay close attention to transmission temps not looking for it to go past 200 degrees. Also have a transmission service done on the car. As you can imagine on the GXP models the transmission is the weakest link.
    If you plan to keep the car long term it is recommended to add an auxiliary transmission cooler.
    Also those look like aftermarket head and tail lights. You will want to make sure they were properly wired and it is known that aftermarket headlights have horrible night time output.
    Also keep in mind that the front tires are wider than the rears. When replacing tires most folks like to go with 245/45/18 size tires all around so they may rotate them.
    Also has an aftermarket cold air intake so the previous owner might not have been gentle since he/she was looking for more performance. Check transmission fluid for color and smell. You want it to be bright red and have no burnt smell. If it is brown and has a burn smell the trans might not be in the best of shape.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: What to look out for on GXP models?
    May 2014
    ft worth
    Thanks for the input buickman! I will keep all of that information in mind. Looks like the intake is K & N?
    Did not even notice the difference in the tires, but being a FWD v8 I am expecting the tires to have a very short life lol
    Quote Originally Posted by buickman104 View Post
  4. #4 Re: What to look out for on GXP models?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Try this:
    Quote Originally Posted by 91parkave View Post
    Go do the GXP commandments.
    Thou shall install a trans cooler
    Thou shall install a shift kit
    Thou shall get a tune.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: What to look out for on GXP models?
    Delaware County, PA
    The V8 engine comes with "Displacement on Demand" ( later called Active Fuel Management) which puts the engine into 4 cyl mode when cruising. This makes the engine use a little oil. It's not a deal breaker, just be aware that it will use some. Make sure the rims say "Alcoa". Always wanted those on my GT. Nice car.
  6. #6 Re: What to look out for on GXP models?
    Apr 2012
    Dayton, OH
    Quote Originally Posted by SpringfieldGT View Post
    You want to get DoD tuned out because its not good on the TC iirc.
    2012 F150 STX
  7. #7 Re: What to look out for on GXP models?
    Apr 2014
    Macomb, MI
    This exactly. I am new to the GXP world and love it! Great cars, just need to be aware of the trans. Every car has their known problems so don't let it steer you otherwise.
    If you ever have questions about the transmission there is plenty info on here as well as contact Dave over at TEP (triple edge performance). I just did and I'm think inking in awhile I'm gonna make the drive from Detroit to Fort Wayne and have him rebuild and beef up my trans just to bulletproof it before anything happens.
  8. #8 Re: What to look out for on GXP models?
    Aug 2013
    Kitchener, Ontario
    My DoD has been tuned so that it only occurs in 4th on the highway. I make a lot of 3 hour trips and it's nice to know I'm saving at lease some gas...lol.
    But I agree with Russ's 3 commandments. Although I'm only following two at the moment
  9. #9 Re: What to look out for on GXP models?
    Aug 2013
    McDonald PA
    91parkave is your guy
  10. #10 Re: What to look out for on GXP models?
    Apr 2012
    Dayton, OH
    Its 91s commandments not mine as I own a GT
    2012 F150 STX
  11. #11 Re: What to look out for on GXP models?
    You should get rid of those head lights if you do buy it, get some stock replacements or some OEM stock ones from someone and just eBay or Craigslist those ones.
  12. #12 Re: What to look out for on GXP models?
    May 2014
    ft worth
    Thanks for all the comments guys
    I am excited
  13. #13 Re: What to look out for on GXP models?
    Arizona
    Side note...even if you have the same size tires the rims them selves are different widths. Its just the nature of how the car was built.
    Like everyone else has already said do not go cheap on maintnence get the trans work done...don't wait especially before summer. Those stupid high trans temps coupled with dod and stock transmission settings will eat it alive very quickly..
    Have fun with the car and feel free to reach out for help
  14. #14 Re: What to look out for on GXP models?
    May 2014
    ft worth
    Interesting, why were they built with different widths?
    When you guys say transmission service, do you mean just a routine flush or are you referring to something more invasive?
    Also, I will try to search around and look into the trans coolers...Got an estimate of what one would run (installed)?
  15. #15 Re: What to look out for on GXP models?
    Arizona
    Quote Originally Posted by SS2GXP View Post
    Yes front Alcoa's are 18x8 rears are 18x7....the trans service is dropping the pan replacing the filter And putting everything back together ..here's the cooler that will work
    http://www.amazon.com/dp/B000CIGE9G/..._3dgBtb0X75E4G
  16. #16 Re: What to look out for on GXP models?
    Aug 2013
    Kitchener, Ontario
    The wider rims in the front are GM's answer to tourque steer. Because it is a FWD V8, it will tend to pull to the side on heavy acceleration and traction loss. The idea of the wider rims in front is that the rear should lose traction first, reducing torque steer. I'm don't really have an answer on how effective it really is.
  17. #17 Re: What to look out for on GXP models?
    Pennsylvania, USA
    Just my opinion really, but I'd personally never flush a transmission. Definitely drop the pan and change the filter, but machine flushes tend to break more than they fix. I have heard it depends on how the machine flushes it, but I've never had good experiences with them. My mother got the transmission flushed on her vehicle when I was younger, and it gave out on us while we were going up a hill the next month.
  18. #18 Re: What to look out for on GXP models?
    May 2014
    ft worth
    I really appreciate all the feedback, guys. I did in fact pick up the car yesterday.
    There are a few minor quirks with the car, but I think I still got a pretty fair deal overall.
    For some reason, the remote key lock does not lock the drivers side door. The door lock moves, but not all the way down to the lock position. All the others work fine, but I have to push it down on the driver side door by hand at the moment. Never dealt with something like that..anyone know what needs to be done in order correct this?
  19. #19 Re: What to look out for on GXP models?
    SWPA
    Quote Originally Posted by Phlip77 View Post
    It's less about torque steer and more about cornering.
  20. #20 Re: What to look out for on GXP models?
    Arizona
    ---this..tourqe steer is a factor under acceleration while having the wheel turned in a given cornering situation
  1. Opinions on 97-03 vs 04+ models
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 06-21-2013, 11:10 PM
  2. Replies: 3
    Last Post: 04-07-2013, 07:30 PM
  3. Buick Models, HW, JL, TW, Books, Litho, Mags,Wheel
    By ABSGTP in forum Buy/Sell Other/Misc
    Last Post: 08-20-2012, 02:01 PM
