Have you tried taking the console out and seeing if it disconnects from the back?
With your foot on the brake pop it in neutral, take a small screw driver and remove the screw holding the shifter knob on and remove it. There's a total of 4 screws on the side of the console (10mm) that need to come off (2 on each side). Remove those and pop the console up. There should 1 or 2 wiring harness underneath the console that you simply unhook and bam console should come all the way out.
