Thread: Plethora of Questions! Advice Needed!
Results 1 to 3 of 3
  1. #1 Plethora of Questions! Advice Needed!
    Apr 2014
    Maplewood
    Ladies and gentleman,
    I have some questions to ask you as a freshly minted owner of a 2000 GTP with some pretty heavy mods. But first, the mod list!
    Before you say it, I know buying a pre-modded car is not the best idea, but it was such a good deal I couldn't refuse.
    The mods claimed to be done by the previous owner:
    Headers
    Catback exhaust from Borla
    Cam (not sure which cam exactly, my guess is one of the more subtle cams based on the sound)
    Intercooler (Tall stack)
    ZZP PCM w/ potentially outdated tune (More on this later)
    H.A.I.
    Stronger Springs
    Lowered
    Mechanical Fuel Pump
    Bigger Injectors (Not sure what #)
    3.1 inch pulley
    Shift kit
    Rockers
    Poly motor mounts
    Transmission rebuilt (not sure what the HP rating is exactly)
    There are probably some that I am forgetting - are there any major supporting mods I should check for to make sure the car is running properly? Obviously some of these are easier to check for than others (like the intercooler). Are there any of these mods that I should somehow verify are done properly?
    Alright, now onto the main questions:
    1) When I first start my car, there is a very large fluctuation of RPM (500-2000) for one-two minutes, then it evens out, idling at about 800 RPM. Sometimes it will die because the RPM drops too low during that initial fluctuation. Does anyone have any ideas as to the cause of this?
    2) I swear that I lose power when TCS is on, even when the wheels are not breaking loose. Is there any chance this is the case, or am I imagining this?
    3) When stepping on it (say to race the riced out mustang that thinks he could take a Bugatti Veyron - yeah, you know what I'm talking about), do you guys suggest downshifting manually, or letting the PCM do the work?
    4) The power steering very intermittently seems to shut off/lose its oomph - I'd say maybe once a week tops. Is this a known issue, or does anyone have any ideas as to the cause?
    5) The previous owner claims that this car has about 500 HP total. If all the mods he claims are done to it are in fact done, I can see this being in the realm of possibility. My old man also has a 2000 GTP that has been heavily modded, essentially the same mods as I have without the intercooler, and he is pulling about 425 horsepower. My question is this - does this HP number seem correct? If not, what mods would need to be done to bring it up to this level?
    6) The car currently has 100,000 miles on it - and the body is very clean (no rust, minimal scratches/dents). The engine seems to run well (no audible knocking), transmission seems to shift pretty well, overall the car is in pretty good shape as far as i can tell. My question here is - what maintenance should I do right away to ensure that everything is running in tip-top shape? Are there any known issues I should check for and address that could cause catastrophic failure in the future if not attended to?
    7) I am thinking about throwing on a 75 shot of NOS later this summer. Do you guys think that the engine can handle this alright?
    8) From what I read, going smaller than a 2.8 inch pulley can be a PITA and requires a new tune. Do you guys think that dropping below a 2.8 is worth it? Would the gains be noticeable?
    9) Has anyone successfully mounted an SD Ram Air hood onto a 97-03 GP with a tall stack intercooler? What did you do to make it work?
    10) Do sway bars really make a difference in handling? Are they worth it if not racing around an autocross track?
    11) The tune. It is probably outdated as the previous owner likely did mods to it since the last tune. I am thinking about buying HP tuner.
    12) The last question (for now) - what other advice do you guys have for me pertaining to this car, or maybe even life in general?
    I would like to now thank everyone in advance for the responses to come - I know these are a lot of questions, some not too easy to answer - but I want this car to run well, and to run for a long time. So I'm trying to cover all possible bases right away.
    P.S. - I have been reading this forum extensivelyfor the past couple weeks. Above are the questions I have not found a solid, conclusive answer to (or maybe I just didn't understand them).
  2. #2 Re: Plethora of Questions! Advice Needed!
    First, get pics of the car, the engine (don't have to be super detailed to start). We may know the car or it's history. Most cars modded to that level had an owner on a forum. Especially since that is the standard W body receipe.
    1. RPM fluctuation when cold. The car is cammed, Darkhorizon has mentioned a lot of times that throwing timing at the idle cells helps this issue.
    2. Very possible, that would be in the tune.
    3. The only time you should pull down manually is from 4th to 3rd right before you jump on it. The 4th clutch hubs are a weak point and should always be protected. Other than that, you can't shift any better than the pcm.
    4. Possibily the Magnasteer is having an issue or the connector is loose. The connector is located near the top back of the trans where the column comes down to the rack.
    5. Only way to know HP is to dyno. You would be talking crank, not wheel if it's up in that area.
    6. You are the eyes and ears currently, check the fluids and go from what you know has been done maintenance wise.
    7. I've heard of them handling it and then you have the other side where...maybe the driver couldn't handle/apply it properly.
    8. Going sub 2.8 requires the snout to be turned down. Which charger do you have? Pics will tell us.
    9. No idea. I used a Stouffers french bread pizze to check clearnance on my Bonneville. That night I ate both unmolested frech bread pizza breads for dinner.
    10. They make a great difference in handling. If you'd like handling, also consider tubular trailing, drag and toe links for the back.
    11. Buy and read...read and read more. Ask tons of questions once you have read.
    12. F body brake upgrade. If you can go fast, you need to be able to stop fast. I nabbed a set off car-part with all the pieces for $60 shipped then added rotors, pads and brake lines. Bled the entire system. Ahhhh it's amazing. Life in general, keep in mind this is a 3800 drivetrain and likely you'll be breaking something if you drive the way I do. This can become expensive and piss a guy off. Knowing up front is good, acknowledging the truth is fantastic and then choosing to drive pretty much the slowest and most reliable 3800 combo after spending billions...... it happens.
  3. #3 Re: Plethora of Questions! Advice Needed!
    PO should know exactly what he put in his car.
    If he doesn't; then I wouldn't buy it.
  1. Advice needed
    By ksteb88 in forum General Tech Discussion
    Last Post: 04-08-2011, 02:40 PM
  2. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  3. Advice needed
    By psav in forum General Tech Discussion
    Last Post: 02-18-2011, 10:25 AM
  4. Advice needed
    By ksteb88 in forum Visual/Body Modifications
    Last Post: 07-29-2010, 10:04 PM
  5. Hello all! Advice needed!
    By jeremylester in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:13 PM
