Thread: Running front o2 in place of rear o2
Results 1 to 15 of 15
  1. #1 Running front o2 in place of rear o2
    Is this ok to do or will it piss off the pcm?
  2. #2 Re: Running front o2 in place of rear o2
    Seems far far too back if you ask me.
    If that what you mean.
  3. #3 Re: Running front o2 in place of rear o2
    I just mean the sensor itself the front used as a rear but plugged into the rear
  4. #4 Re: Running front o2 in place of rear o2
    Dec 2012
    troll land
    ^kinda curious myself. I have a friend that needs a front o2 and i have a spare downstream
  5. #5 Re: Running front o2 in place of rear o2
    Compare part numbers you noobs.
  6. #6 Re: Running front o2 in place of rear o2
    They are different numbers but I didn't know how bad it would piss off the pcm
  7. #7 Re: Running front o2 in place of rear o2
    Might be the same sensor, but the connectors are different.
  8. #8 Re: Running front o2 in place of rear o2
    hangover park IL
    same sensor, connectors are different and are crimped stainless wire so youll have no luck modifying it, which means you get to cut up your oem harness and splice on a front O2 connector after you grab a pigtail off a junk car.
    so you just spent an hour or more to reuse a 40$ O2...and if its got about 50k or more miles on it, consider it junk and move on...
    ~James~ Psychotic Gearhead
  9. #9 Re: Running front o2 in place of rear o2
    I'm just trying to do some diagnostics on my car and had a newish front o2 laying around
  10. #10 Re: Running front o2 in place of rear o2
    hangover park IL
    take a note of which wires go where in the factory connector
    yank out the pins and connect them directly and wedge them in place with slivers of wood/straws/coffee strikers, and you should be able to make it work while still being reversible
    Ask me how I know
    Ps McDonald's straws work great if you slit em and wedge em together into an "atomic + sign"
  11. #11 Re: Running front o2 in place of rear o2
    hangover park IL
    but for most diagnostic purposes if your base tables are fairly well tuned all you need to do is unplug the o2 sensor and see how it runs after disconnecting the battery or resetting trims.
    aside from the obvious physical damage to the body of the sensor most damage tends to be contamination and skewing of the stoichiometric mv point or heater failure.
  12. #12 Re: Running front o2 in place of rear o2
    I haven't had a rear o2 for almost a year and was just trying to see if made any difference with it hooked up.
  13. #13 Re: Running front o2 in place of rear o2
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Rear o2 will not effect how your car runs. On some foreign cars having an emissions code will disable cruise control but other then that it does not effect our cars.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  14. #14 Re: Running front o2 in place of rear o2
    Yes it does, cars with cat tests can affect how it runs.
  15. #15 Re: Running front o2 in place of rear o2
    Apr 2011
    South Dakota
    I have tuned the rear o2 out of 5 different 3800 powered cars now and the worst thing I have seen is the pcm commanding it rich under cruise for a minute and then returning to normal on a 2004. I never understood why everyone was so worried about it.
    I love Decker<3
  1. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
  2. any1 running 255 45 17 on the rear???
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 02-16-2009, 03:13 AM
  3. subs in place of rear speakers?
    By kamikaze275 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 10:01 PM
  4. Front or Rear?
    By J_Man55 in forum Brakes/Suspension/Chassis
    Last Post: 07-13-2008, 01:26 PM
