Thread: DIY intake help
Results 1 to 20 of 24
  1. #1 DIY intake help
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    im in the middle of a diy intake and need some help with two parts.
    What do you do with this thing? im not really sure what people have done with it.
    Also what do you do with this metal...thing. should i just secure it to the frame?
    This is my setup
  2. #2 Re: DIY intake help
    Yeah, that is your MAF, you kind of need that.
    and the PCM most of us just zip tie it down.
  3. #3 Re: DIY intake help
    Blowes or Homo Depot 3" plumbing coupler with a fitted hole for the PCV connection, attached to TB and MAF, then a coupler/extension to add the air filter.
  4. #4 Re: DIY intake help
    Just an FYI, this doesn't add power, just noise.
  5. #5 Re: DIY intake help
    Apr 2013
    Fowlerville
    ok thanks drunkie your the bomb. i need to get another extension from the MAF to the filter... is it a no no to drive with out that on.. for me to run to the store and grab the coupler.. or should i put the stock box back on
  6. #6 Re: DIY intake help
    Throw the stock air box back on you need a functioning maf
    04 Comp G.
  7. #7 Re: DIY intake help
    You need that MAF, so stock box back in.
  8. #8 Re: DIY intake help
    London Ont, Canada
    If it's 04+ make sure you assemble your intake in same sequence as stock. There are a million threads around here about building intakes. Search button and just follow what others have done. Less work that way.
  9. #9 Re: DIY intake help
    Apr 2012
    Bancroft. Ontario, Canada
    Quote Originally Posted by Grandprix202 View Post
    If you cant recognize your PCM. You probably shouldn't be modding a car ahah
  10. #10 Re: DIY intake help
    Apr 2013
    Fowlerville
    Quote Originally Posted by Speedy1973 View Post
    Hey we are all rookies once in our life... I never new the pcm was in the air box and wasn't sure what it was.
    Sent from my SM-N900P using Tapatalk
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  11. #11 Re: DIY intake help
    Apr 2012
    I hear ya. So how did this turn out? got a pic of the finished product?
  12. #12 Re: DIY intake help
    Apr 2013
    Fowlerville
    Yea I do but I gotta wait until I get to my computer since I'm on tapatalk right now... I'm so impressed... I mean the engine just sounds like it just has so much more guts. It sounds so much throaty and deep I love it.
  13. #13 Re: DIY intake help
    Apr 2013
    Fowlerville
    And I love that it only cost me 30 smackaronies
  14. #14 Re: DIY intake help
    Oct 2011
    Toledo, OH
    If you leave the front/bottom half of your air box in, it coincidentally works perfectly to hold the PCM in place...
    7"
  15. #15 Re: DIY intake help
    Apr 2013
    Fowlerville
    finished product... sorry for the extremely dirty engine bay... went 4x4 trying to get up driveways this spring and haven't cleaned it up yet
    I still need the coupler from the MAF to the PVC pipe. it was a really tight fit but its not leaking at all so it will last until i can make it to home depot.
  16. #16 Re: DIY intake help
    Apr 2013
    Fowlerville
    another sorry for my plasti dip mess i haven't cleaned up yet... im ashamed
  17. #17 Re: DIY intake help
    Nov 2010
    Baltimore
    I would never use pvc pipe on a diy intake. That **** gets hot!!! Next time after a good drive pop your hood and put your hand on it. I know that's what most people use, but compared to the accordian style tubing that pvc has to be at least 20 degrees hotter..maybe more. When i say accordian i mean after market. Like the silver colored type.
  18. #18 Re: DIY intake help
    Aug 2013
    McDonald PA
    My PVC stays cool as can be?
  19. #19 Re: DIY intake help
    Apr 2013
    Fowlerville
    Yea... man to be honest I went for a good 15-20 minute drive and i made a stop just to see how everything was holding up and it was cool-warm to the touch...
  20. #20 Re: DIY intake help
    Apr 2012
    Quote Originally Posted by Theaceofspades View Post
    Yeah i'm with you, i've had my same DIY intake on my 3 gp's and i've never had it get that hot, maybe warm, but not hot.
    Also, for the OP. I'd have went with a 45deg peice of pipe, rather that 90. There's nothing wrong with the 90deg, but personally, it just looks a little "odd"
    Turned out well. Next mod should be matching the UIM with the same colour paint/powdercoat as the dogbones/diagonal bracing.
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  3. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
