Thread: 1995 camaro oil leak
Results 1 to 7 of 7
  1. #1 1995 camaro oil leak
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    I know this is a grand prix forum I just sold my grand prix and been on the forum for a while. But i just purchased a 1995 camaro v6 and i have an oil leak. It only leaks when i hit the accelerator. The leak is coming out of that black hole on the bottom left of the photo and also out of the black part of the top right bolt. I just have no idea what that black piece is. It looks like it connects to the transmission. If anyone knows how to fix this problem or what it is I would appreciate it. Thanks guys!
  2. #2 Re: 1995 camaro oil leak
    Thats just a shield for the flexplate/flywheel.
    If it's leaking oil from there, you likely have a bad rear main seal or the rear cover gasket is leaking.
  3. #3 Re: 1995 camaro oil leak
    yeah I figured it was a rear main seal. Any idea on how to replace something like that. I heard its not easy
  4. #4 Re: 1995 camaro oil leak
    Remove the transmission.
  5. #5 Re: 1995 camaro oil leak
    you can unbolt the cover and look up for oil. ( you'll need a flash light) it could be valve cover gaskets leaking down to that area too.
  6. #6 Re: 1995 camaro oil leak
    so the only way to fix it is to take the whole tranny out? theres no other way. Im going to try to buy real seal stop that you put in the oil. I heard good reviews from it. Im sure its not going to work lol
  7. #7 Re: 1995 camaro oil leak
    take a paper towel fold it up in quarters, then wipe under the valve cover lip. if its wet thats your leak.
    check the easy fixes before dumping oil leak stop, or dropping the tranny out.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. 1995 bmw m3
    By 99gp in forum For Sale - Vehicles
    Last Post: 03-21-2012, 09:57 AM
  4. will a 1995 2 door bumper cover fit a 1995 4 door?
    By pjgilboy in forum Introductions/Noob Questions
    Last Post: 12-11-2009, 12:45 PM
