2002 GTP so about a month ago I rebled the cooling system because I knew I had a air pocket in it and everything was good. Now when I am at WOT the temp climbs and when I'm off the gas it stays where it climbed to and slowly drops until I get back in the gas a little bit it also when at a light will slowly climb but once I'm going it drops down.
The water pump is brand new less than four months old thermostat is about a year old no leaks no coolant in the oil.
I'm going to bleed it again to rule out a air pocket. I'm also gonna check the radiator as best I can hopefully its not that because it doesn't look like a good time to replace it.
Any feedback is great feedback and appreciated thank you in advance.
Sent from my HTCONE using Tapatalk
