Thread: Car jumps on bumps
Results 1 to 10 of 10
  1. #1 Car jumps on bumps
    Mar 2014
    SE PA
    I don't know if this is normal but I wanted to get to the bottom of this. If I ever go over a bump in the road (more pronounced at higher speeds), my car seems to "hop" a little bit to the side. This is especially annoying when I'm on the highway and the bump is on a curve, so as I'm turning, my car jumps a decent bit. Is this normal? If not, what is wrong here? If it is normal, will a better sway bar/strut tower braces fix this?
  2. #2 Re: Car jumps on bumps
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    My car will jump to the side a little if i'm going over a bump on a curve on the highway but it only slightly does. If i'm just driving normal and go over a bump it doesn't happen. Have you checked to see if your front swaybar is cracked where the links are?
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  3. #3 Re: Car jumps on bumps
    Mar 2014
    SE PA
    I didn't get a chance to remove the wheels to get a better look but from what I can see, it looks fine. It's a 2007 though and the previous owners were an elderly couple (apparently they drove it so slow that the computer recorded an avg of 24mpg ) so I wouldn't expect the sway bar to be cracking yet. My old Passat used to do the same but that went away as soon as I put a strut tower brace on it.
  4. #4 Re: Car jumps on bumps
    Oct 2013
    MARYLAND
    I don't think i've really had a problem with mine "hopping" unless i'm going around a turn over a bump. From what i've seen 24 mpg is pretty normal, i'm usually around 24-27
    -Thomas Fuller-
  5. #5 Re: Car jumps on bumps
    Mar 2014
    SE PA
    Quote Originally Posted by MCbatt View Post
    Seriously??? I barely even get anywhere near 27mpg on the highway, how is your DIC telling you that you get 24-27 avg?
  6. #6 Re: Car jumps on bumps
    Oct 2013
    MARYLAND
    Don't have a DIC in my car
    -Thomas Fuller-
  7. #7 Re: Car jumps on bumps
    My 97 did that, sometimes it would hop so much the low trac light would come on.
  8. #8 Re: Car jumps on bumps
    Oct 2013
    MARYLAND
    Oh thats not a DIC, thats just doing the math at fill ups
    -Thomas Fuller-
  9. #9 Re: Car jumps on bumps
    Nov 2011
    NY
    Year, make, mileage? Granny driving it doesn't matter. What matters is the mileage or age of suspension components. More info. Required!
    And moving laterally when slightly airborne is normal @ higher speeds mainly due to being out of contact with the ground for a longer period of time. Lolz
    Otherwise, yeah, probably some worn stuff. Swaybar, swaybar bushings, struts, control arm bushings, etc...
  10. #10 Re: Car jumps on bumps
    Mar 2014
    SE PA
    Quote Originally Posted by coolone View Post
    Sir, I got a 2007, base boy, 83k mileages. I've never had a car that hopped like this, it seems kinda dangerous to be honest. Struts seem fine, same with sway bars. Can't comment on the control arms because I haven't looked at them yet.
    I was reading something about how lowered cars tend to "pogo" because of the top plate washers and found this http://shop.zzperformance.com/store/...o-Washers.aspx
    Is it possible for a non-lowered car to pogo? Is what I'm describing even a pogo??
  1. Help... Car jumps under acceleration
    By 3R1CD4V15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2012, 05:12 PM
  2. My 2004 grand prix power jumps in and out 3500+ rpm
    By jay1881 in forum General Grand Prix Discussion
    Last Post: 03-16-2012, 02:10 PM
  3. [Jumps off Bridge]
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 10-04-2011, 10:03 PM
  4. brake pedal jumps when applied
    By tipatalon in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 06:17 PM
  5. tach jumps
    By wilder9032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2010, 06:27 PM
