Thread: Where to find out what info is available from the obd
Results 1 to 5 of 5
  1. #1 Where to find out what info is available from the obd
    Aug 2013
    Kitimat, B.C.
    Trying to find out what info (sensors) are supported through the obdII port. Not looking at codes. Trying to set up a gauge display on my ipad.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Where to find out what info is available from the obd
    Omaha, NE
    An Aeroforce Interceptor gauge can read:
    RPM
    MPH
    Intake Air Temperature (post Intercooler)
    Ambient Air Temperature (pre Intercooler)
    Engine Coolant Temperature
    Exhaust Gas Temperature (PCM Calculated)
    Transmission Temp. (auto trans)
    Manifold Pressure (vacuum/boost) displayed in PSI
    Fuel Temperature
    Battery Voltage
    Battery Temp
    Injector Pulse Width in msec.
    Injector Duty Cycle (%)
    Air Flow Rate into engine
    Long Term Fuel Trim
    Short Term Fuel Trim
    O2 Sensor Voltage
    Barometric Pressure
    Ignition Advance
    Base Spark
    PCM Spark Adjust
    Fuel Status (open/closed loop)
    Wastegate Solenoid Duty Cycle (%)
    Knock Retard
    Knock Sensor Raw Voltage
    Throttle Position Percentage
    Throttle Position Sensor Raw Volts
    Calculated Net Horsepower
    Engine Load
    Transmission Slip
    Current Transmission Gear
    Torque Delivered to Transmission
    Torque Converter lockup status
    Brake pressure
    Brake Booster Travel
    Steering Angle
    Non-driven Wheel Speed
    Lateral G's
    Yaw
    Fuel economy (instantaneous and average)
    P-ratio - pressure ratio MAP/Barometer
    2 user configurable analog inputs**
  3. #3 Re: Where to find out what info is available from the obd
    Nov 2011
    NY
    Here ya go...
    http://www.obdii.com/
    Now it just depends what app you're using and what it's set up to do/read.
  4. #4 Re: Where to find out what info is available from the obd
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Well technically speaking you can read just about anything that the pcm is aware of.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: Where to find out what info is available from the obd
    Aug 2013
    Kitimat, B.C.
    Thanks I'm using dashcommand now but am thinking of adding ultra-gauge.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Need Info
    By sexxy1969 in forum Introductions/Noob Questions
    Last Post: 11-18-2013, 12:46 PM
  3. first days!!! any info of good info
    By 97gtp83boy in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 02:17 AM
  4. New here, how do I use search to find specific info?
    By malcolmk in forum Introductions/Noob Questions
    Last Post: 01-24-2012, 03:37 PM
  5. DIC info
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 10:41 PM
