Thread: Help...Please
Results 1 to 16 of 16
  1. #1 Help...Please
    Mar 2012
    Michigan
    I have a 01 grand prix gt 3.8l it has 152,000 and it's not super charged...the problem I am having is the gas gauge is starting to jump...when I start the car it will read 1/4 of a tank, then when I drive it down the road the gauge will say I have a half of tank...what is going on with my car.
    Thank you
    Sammie
  2. #2 Re: Help...Please
    Dec 2010
    DMV
    Fuel sensor is going out. It's in the gas tank.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Help...Please
    the gas tank level sensor is bad. theres a dorman repair part for it. you have to pull the fuel pump out and replace one part on the canister, its like 20 bucks on line for the part.
  4. #4 Re: Help...Please
    Mar 2012
    Michigan
    Ok..Thank you
  5. #5 Re: Help...Please
    But with that many miles you might as well just replace the pump while you are in there.
  6. #6 Re: Help...Please
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    my 2000 3.1 was doing the same thing. I got a sending unit then went on youtube to see how to change it. Since I had to take the pump out to do it and it was probably the original pump I just changed the whole thing. A pump for yours on ebay is $45 with the unit and new float already attached.
  7. #7 Re: Help...Please
    Mar 2012
    Michigan
    I did the little test...turned the key part way and I can hear the pump working, my car doesn't stall or start hard.
  8. #8 Re: Help...Please
    the pump comes right up and out via the trunk so to get it out later on again's not the end of the world to replace another part later on.
    should the pump die you can change just the pump too. vs the whole canister, thats where they rape your wallet.
    id never buy a 45 dollar pump and canister off ebay either. ive found just the pump for 30 and less on ebay, those i would buy.
  9. #9 Re: Help...Please
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Dont bother with the pump. Doorman makes a plug and play kit to fix the level sender in a hour.
    http://www.oreillyauto.com/site/c/de...l+level+sensor
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  10. #10 Re: Help...Please
    Frosty works slow.. takes me about 15min. Super simple.
  11. #11 Re: Help...Please
    Apr 2011
    South Dakota
    Itll be his first time so I was allowing him some leeway! I agree with your 15 minutes after you've done it before. It really depends how many beers you have beforehand
    I love Decker<3
  12. #12 Re: Help...Please
    Apr 2011
    South Dakota
    Quote Originally Posted by SpeedGrid View Post
    If you can fix it yourself that willl be great.
    But if you will take it to a shop I have a feeling the labor for fixing the car will cost more than the car itself.
    If a shop charges you more then 150$ you should tell them to **** off. A running driving car is worth a helluva lot more.
    I love Decker<3
  13. #13 Re: Help...Please
    Says the guy who paid a shop to install his cold air intake.
    Sent from A Galaxy Far Far Away........
  14. #14 Re: Help...Please
    Dec 2010
    DMV
    Lmao ^^
  15. #15 Re: Help...Please
    Rofl
    04 Comp G.
  16. #16 Re: Help...Please
    A bajillion.
