Thread: need advice on modded fuel rails
Results 1 to 20 of 31
  1. #1 need advice on modded fuel rails
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    I just bought an intercooler from gmr, so im trying to figure out the fuel rail situation. I wanted to know if anyone has tried modifying them their selves by that i mean take it to a welding shop and tell them what to do.
    There is a local weld shop that can do just about anything you ask of them and they are very resonable, im sure they are fully capable of brazeing them but i need to have an idea of how they are built. Does anyone know
    of a build thread where someone did this, or better pictures than zzp page
  2. #2 Re: need advice on modded fuel rails
    Mar 2012
    NC
    You could also try injector spacers I guess...or REALLY beg GMR for his Aeromotive fuel rails...or buy them new for like $250...they're really nice rails and add a little extra flair under the hood.
  3. #3 Re: need advice on modded fuel rails
    Zzp modded rails are 150 plus your stock ones plus shipping
  4. #4 Re: need advice on modded fuel rails
    Jun 2013
    brookville,IN
    he never mentioned them to me, i pretty much just blew all my money on this thing so im trying to go cheap with the rails, i figured i could pick some up at the junk yard and mod them prior to install. Anyone know what kind of fittings i should use
  5. #5 Re: need advice on modded fuel rails
    Jun 2013
    brookville,IN
    I think there 200 for return style but i could probably get some made for less than 50
  6. #6 Re: need advice on modded fuel rails
    Mar 2012
    NC
    Injector spacers are about $30 plus shipping from Racetronix. He's gonna want a pretty penny for those rails though.
  7. #7 Re: need advice on modded fuel rails
    I want to say the guy that modded his himself was named kejkross or sumthing like that..
    04 Comp G.
  8. #8 Re: need advice on modded fuel rails
    You could use rubber fuel injector hose and hose clamps
  9. #9 Re: need advice on modded fuel rails
    ^ which seems a bit risky don't you think
    04 Comp G.
  10. #10 Re: need advice on modded fuel rails
    Risky schmisky
  11. #11 Re: need advice on modded fuel rails
    Jun 2013
    brookville,IN
    he told me spacers wont work
  12. #12 Re: need advice on modded fuel rails
    Jun 2013
    brookville,IN
    your crazy dan there is no way i would use rubber lines lol
  13. #13 Re: need advice on modded fuel rails
    Mar 2012
    NC
    16.1mm spacers should work just fine. Injectors stay in the heads and run the spacers between the fuel rails and the injectors. Spray pattern would remain unaffected and you can make rail mounting point spacers out of 3/8" steel fuel line cut and filed to length.
  14. #14 Re: need advice on modded fuel rails
    Florida
    Cut the lines that cross over the SC, have a shop weld/braze male AN fittings, and make your own custom length lines to go over?
    Or to make it cleaner, have them chop all but the horizontal rails, then connect them like the fuel logs are, all with welded/brazed AN fittings.
  15. #15 Re: need advice on modded fuel rails
    Feb 2013
    Detroit, MI
  16. #16 Re: need advice on modded fuel rails
    Hey there's that guy I was mentioning good job Kory you finally did something right.
    04 Comp G.
  17. #17 Re: need advice on modded fuel rails
    Feb 2013
    Detroit, MI
    Lol I've had that bookmarked for some time now
  18. #18 Re: need advice on modded fuel rails
    And yet he bought fuel logs
    04 Comp G.
  19. #19 Re: need advice on modded fuel rails
    Feb 2013
    Detroit, MI
    Got em for free basically, and a turndown
  20. #20 Re: need advice on modded fuel rails
    Just keep them nice and neat for me for when I come steal your s**t!
    04 Comp G.
  1. Modded fuel rails, ported tb
    By chamberlain198437 in forum Wanted To Buy - Parts
    Last Post: 05-23-2014, 03:14 PM
  2. L67 modded fuel rails
    By txslow6 in forum Wanted To Buy - Parts
    Last Post: 02-25-2012, 09:38 AM
  3. WTB: Modded fuel rails for 01 gtp
    By samuelcb409 in forum Wanted To Buy - Parts
    Last Post: 02-09-2012, 07:31 PM
  4. modded fuel rails
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2011, 10:56 PM
