Thread: Best place to put wideband sensor
Results 1 to 4 of 4
  1. #1 Best place to put wideband sensor
    Donating Users timboku's Avatar
    Montgomery, IL
    Wheres the best place to put.the sensor. I have sd headers and no cat. Can I use the rear o2 sensor hole is that to far away from the headers?
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: Best place to put wideband sensor
    That's what I use but I hear it should be closer
  3. #3 Re: Best place to put wideband sensor
    May 2008
    Schuyler, NE
    Typically the best place to put it is in the exhaust.
  4. #4 Re: Best place to put wideband sensor
    Mar 2012
    NC
    I believe it is supposed to be within 18" after the header collector. I put mine in close proximity to my O2 sensor...not too close that it'd screw up readings, but close as in "hey, this car has two pre-cat O2's!" to the inexperienced tech.
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
