Thread: Intake Manifold Runner Ctrl Stuck Open
Results 1 to 19 of 19
  1. #1 Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Started getting a code yesterday...
    P2004 Intake Manifold Runner Ctrl Stuck Open Bank1
    cleared it and it came back today
    what should I look at before I have to run it to a shop?
    I have a 2008 Base GP
  2. #2 Re: Intake Manifold Runner Ctrl Stuck Open
    Enfield, CT
    check the electrical connections and vacuum hoses around it. make sure there are no cracks on the hoses or breaks in the wires. good luck
  3. #3 Re: Intake Manifold Runner Ctrl Stuck Open
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I wasn't aware a 3800 had any sort of runner control?
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  4. #4 Re: Intake Manifold Runner Ctrl Stuck Open
    Mar 2012
    NC
    Quote Originally Posted by frosty View Post
    My thoughts exactly.
  5. #5 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    no idea, that's the code the car is throwing...
    I cleared the code again, shut it down restarted and boom check engine P2004
  6. #6 Re: Intake Manifold Runner Ctrl Stuck Open
    You are 100% sure its P2004?
    Maybe its P0204?
    We don't have a valve that controls runners in our cars. The only air type valves are for the cali emissions cars with an air pump.
  7. #7 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    YEP!, just checked it again.. I have two codes P2004 and P2431 the second one popped up tonight....
  8. #8 Re: Intake Manifold Runner Ctrl Stuck Open
    Air injection system like I figured, stupid air pump cars.
  9. #9 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Guess I'll be replacing the air injection solenoid and see if that fixes it... things a pain in the ass to get to though
  10. #10 Re: Intake Manifold Runner Ctrl Stuck Open
    Apr 2011
    South Dakota
    Or get a tuned pcm and delete that stupid system
  11. #11 Re: Intake Manifold Runner Ctrl Stuck Open
    2008 = can bus = can't ever be tuned.
    Thus finding and reparing the problem is needed.
  12. #12 Re: Intake Manifold Runner Ctrl Stuck Open
    Apr 2011
    South Dakota
    ****... I just kinda assumed they left it alone that year but I guess gm rewired it.
    I love Decker<3
  13. #13 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Hey guys, any idea why this is doing this... I have an Innova 3130 canOBD2 reader my emission status is red (makes sense) but I have flashing systems (means they aren't initialized yet) they are CAT, EVA, AIR, O2S, HTR, EGR... These have been flashing from the day I bought the car brand new... and my emission state light has NEVER been green, it's always yellow.
    any idea what would cause those systems to never initialize?
  14. #14 Re: Intake Manifold Runner Ctrl Stuck Open
    Some of those do take upwards of 20-30min drives to go through a full test.
    Not sure if you do drive the car enough miles at a time.
  15. #15 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Drove it for 2hrs and over 150 miles today and they are still not initialized / blinking after checking with never shutting the engine off...
  16. #16 Re: Intake Manifold Runner Ctrl Stuck Open
    Hmm, honestly I am not really sure on this one. My state doesnt have emission testings so it's something I havent really looked at before. And I'm not familiar with that scanner.
  17. #17 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Ok, the dealer wants thousands to "diagnose and fix this"... no way in heck because it's not even guaranteed...
    Now it's throwing a U1153 code in addition to P2431 and P2433
    the original code I got never showed up again after I reset them the first couple times...
    the weird thing is this all started this way... I did a remote start on my car, it was running fine, I got in turned the key to run, When I did that the car instantly died and started itself back up almost like it never died but I know it did for about 1 second... when it came back on that's when the CEL came on... and gave me the initial codes I got... that have been showing up ever since...
  18. #18 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    Well, I gave in and figured I'd try to fix it myself..
    Codes I was getting were P0411, P2431 and P2433. Everything seemed to point to the Secondary Air Injection Check Valve / sensor.
    This solenoid valve / Sensor assembly is in the back center of the engine compartment, and looks like a canister that has a tube from the air pump in the drivers front side of the engine bay to it and a metal corrugated tube from the bottom of it into an exhaust connection on the back of the engine to allow extra air into the exhaust stream.
    Air pump seemed to be trying to run, so that wasn't the issue, relay (which is on the drivers side front wheel well, not in inside the fuse box hanging from a plastic hanger) worked fine, the 50 AMP fuse for it tested fine also. Only left two possible problems... a line was clogged or the valve was bad.
    I got the valve assembly, which included a new bracket, the solenoid valve and sensor and a new corrugated pipe off Amazon for $150 and a new gasket which isn't included for $5
    Gasket is ACDelco 219-600 Air Check Valve Gasket
    Assembly is ACDelco 12619122 OE Service Secondary Air Injection Shutoff and Control Valve Assembly
    Changing it was the most annoying part, but not too hard, hardest part was having the right tools that fit into tight spots..
    1) Remove oil fill spout and the engine top cover it holds down
    2) Remove the driver side support bar that connects from the front to the wheel well top (3 bolts total) and disconnect it from the cable that is clipped on to it underneath
    3) Disconnect the MAF, remove the air intake tube and the PCV ventilation tube that plugs into it, remove from engine bay
    4) take the tube from the air filter to the air pump off (compression clip on air filter box)
    5) remove air filter box front and filter if you more room to get to the air pump under it
    6) disconnect the air tube from the air pump to the Solenoid valve squeeze the plastic clip and pull back it will slide right off
    7) remove the 10 mm bolt that holds the air tube on the right under side of the throttle body
    8) disconnect the air tube from the solenoid / check valve the same way as you did at the air pump and then remove from engine bay
    9) remove brake booster tube from engine so you have room to get to the valve bracket bolts
    10) remove the wire plug from the solenoid / check valve top
    11) remove the two 1/2" bolts infront of the valve. The valve is attached to a black metal bracket held in by four bolts. Two bolts on the top and two behind the engine.
    12) disconnect the wire harness that goes to the O2 sensor behind the engine that is attached to one of the black brackets (the bracket that your engine cover slides into for support)
    13) follow the bracket down the back, there are two more 1/2" bolts that are about 4 inches long that need to come out.. these are a pain to get out and in but it can be done with the right length wrench attachment.
    14) on the bottom of the valve there is a tube that goes into another tube. this is where the gasket goes on, there are two 10mm nuts that need to come off here. remove them, it's tight but you can do it with a small wrench and a long neck 10mm socket
    15) put it all back together in reverse, just remember to put a new gasket on
    took me about 30 minutes to do with no experience doing this
  19. #19 Re: Intake Manifold Runner Ctrl Stuck Open
    Nov 2011
    Indiana, PA
    I'll add that after doing this, my engine seems quieter at start up, the check engine light is gone now and hasn't come back yet (you will have to do a reset of the light to get it to go away of course)... saved me hundreds of dollars... dealer wanted $1,500 to diagnose it and repair it if it was the valve / sensor... cost me $160 after shipping
  1. HELP-hood latch stuck open
    By fst in forum General Grand Prix Discussion
    Last Post: 01-19-2012, 12:33 PM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. Fuel injectors stuck in intake manifold
    By dsmuts in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2011, 04:51 PM
  4. sunroof visor stuck open
    By hourang in forum General Tech Discussion
    Last Post: 06-30-2010, 04:42 PM
  5. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
