Thread: Gtp. Map and maf
Results 1 to 11 of 11
  1. #1 Gtp. Map and maf
    Aug 2013
    ny
    P0102 code pops up. Replaced the sensor that by the throttle body. Is that a map or maf? Wjere is the other one located
  2. #2 Re: Gtp. Map and maf
    Dec 2010
    DMV
    That's the maf sensor located on the throttle body. The map sensor is in the rear of the engine on the top.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Gtp. Map and maf
    Dec 2012
    Where 4T65E's were born
    P0102 - Mass Air Flow (MAF) Circuit Low Input
    Sold.
  4. #4 Re: Gtp. Map and maf
    Aug 2013
    ny
    Ty guys. I replAced it. Dunno y it shows code. I reset it.
  5. #5 Re: Gtp. Map and maf
    check the wires to the plug for the maf for cracks or bare wire showing.
    also check your fuse box, that the low voltage code, its fuse may have blown. same for the wires, bad wires will make the low voltage code pop up.
    maf maybe just fine.
  6. #6 Re: Gtp. Map and maf
    Aug 2013
    ny
    Under hood box?
  7. #7 Re: Gtp. Map and maf
    id check both fuse boxes. im not sure where it lives.
  8. #8 Re: Gtp. Map and maf
    Aug 2013
    ny
    Kk whats it labled as?
  9. #9 Re: Gtp. Map and maf
    Arizona
    Its like number 23 or something in the underhood fusebox. Just look for a blown fuse. It won't take long.
  10. #10 Re: Gtp. Map and maf
    GT Level Member al2000gtp's Avatar
    Buda,IL
    Its number 21 in Underwood box. Im battling this right now too. I changed by o2 sensor cuz it was throwing every code you could get for the upstream o2 lol and after change it would blow that fuse. Thought it was just a bad o2 so tired another and same thing. Did find out though that both o2s (I think) and the evap solenoid and maf are all wired to that same circuit so ive got some wires to trace down and find the short
    Sent from my SCH-I535 using Tapatalk
    2000 GTP - HAI, SD Headers, 3" catback, cat delete, thrush turbo muffs, self ported sc, and transgo shift kit.
  11. #11 Re: Gtp. Map and maf
    Buda,IL
    Under hood box... stupid auto correct
