Thread: Front window defroster problems
Results 1 to 4 of 4
  1. #1 Front window defroster problems
    Mar 2014
    Fort Wayne
    I have a 2006 Grand Prix and it has the dual climate control. Last year I noticed that the front defroster wouldn't work sometimes. It doesn't switch over correctly and when you turn it on the air blows down by my feet instead of the front window. I used to be able to switch it back and forth a couple times and it would fix itself but it's not switching back anymore. Is this going to be hard to fix? And expensive?
  2. #2 Re: Front window defroster problems
    Mar 2012
    NC
    It sounds like the actuator for that control door has failed. The last one I did was a giant PITA and should've required dash removal.
  3. #3 Re: Front window defroster problems
    Mar 2014
    Fort Wayne
    Is that going to be expensive?
  4. #4 Re: Front window defroster problems
    you need to open up the lower dash and check to see if the rods are moving off the vac pumps. if one of the rods broke the dash sorta need to come out to fix it.
    you can also check to see if the vac line off the fire wall is plugged in still, the air flow direction works off vacuum from the engine.
  1. window defroster
    By Thinksun in forum General Grand Prix Discussion
    Last Post: 09-18-2013, 05:00 PM
  2. Rear Window Defroster - Fuse/Rely Location
    By 99XC600 in forum General Tech Discussion
    Last Post: 12-10-2012, 07:49 PM
  3. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
  4. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
  5. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
