My brother recently picked up a GTP and when he locked it it sounded the alarm/horn (like most cars do)
My car does not. He said there was a way to change that...did some searching with no luck.
Anybody?
Anybody?
If it's a 04+ it's programmable through the DIC
Not sure on the previous gen
Found this on GPONA:
How to program:
1 Turn off the IP dimmer switch
2 Turn ignition switch to OFF position
3 Remove MALL PGM fuse
4 Turn ignition switch to ACC position
The BCM sounds the chime a number of times equal to the BCM installed in vehicle (1-4 times) Make sure BCM is Type 3 or 4.
Now the BCM has entered the feature customization mode.
5 To change the remote unlock control mode, press and release the unlock button on the transmitter.
The BCM will sound the chime equal to the remote unlock control mode. A transition past Mode 2 repeats the sequence starting with Mode 1.
Remote Unlock Control Modes
Mode 1 (disabled) All doors unlock when pressing unlock on transmitter
Mode 2 Driver's door unlocks when pressing unlock once on transmitter, press unlock again within five seconds unlocks all doors
6 To change remote activation verification mode, press and release the lock button on transmitter. The BCM will sound the chime equal to the remote activation verification mode it is in. A transition past Mode 4 repeats sequence with Mode 1.
Remote Activation Verification Modes
Mode 1 Feature disabled
Mode 2 Headlamps flash when pressing unlock or lock on transmitter.
Mode 3 Headlamps flash when pressing unlock on the transmitter. Headlamps flash and horn sounds when pressing lock on the transmitter.
Mode 4 Headlamps flash when pressing unlock on transmitter. Headlamps flash when pressing lock once on transmitter; within five seconds, headlamps flash and horn sounds when pressing lock again on transmitter.
To exit and save: Turn ignition switch to OFF, Reinstall MALL PGM fuse
Perfect. Don't have the owners manual currently
i don't know who set it up this way but it drives the little OCD I do have crazy. Constantly feel like my car isn't locked when I don't hear a beep.
http://www.pontiac.com/content/dam/p...ers-manual.pdf
happy reading. first thing i did when i got my car was read this dumb thing, lots of stupid in there, but then you find something you didnt know about.
