Thread: Hard shifting
Results 1 to 7 of 7
  1. #1 Hard shifting
    Feb 2014
    Colorado
    Hey everybody, I have an '02 SE with the 3.1L. It's my understanding this has the same transaxle as the 3.8L. So I'm having this problem where every now and then the trans will start shifting hard like the revs are not matched or something. If I turn the car off and on again, it goes away…so I'm thinking it's not temperature related. Any ideas or common remedies? Thanks, btw the car has about 100k
  2. #2 Re: Hard shifting
    Aug 2013
    arlington, tx
    Would it only do it in first gear? Cold start?
  3. #3 Re: Hard shifting
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    p1811 have the car scanned
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  4. #4 Re: Hard shifting
    Dec 2012
    Where 4T65E's were born
    It's likely the PCS failing, pressure is too low when the computer tells the PCS to create a higher pressure, it doesn't and shifts get real slow which most people don't notice. The computer reads the shift timing and realizes it's slow and causes max pressure as a fail safe so it doesn't slip.
    And it is often temperature related. When it gets hot is usually when the shifts get slower, cycling the ignition resets the code said above ^ and starts over but eventually will re-detect it and set it again.
    Sold.
  5. #5 Re: Hard shifting
    Feb 2014
    Colorado
    Hmm I scanned the OBD2 a couple weeks ago (when the problem was still happening) and the only code was 440 (vac leak). PCS sounds possible though. The problem has no consistency and I can drive the engine warm on long trips and it may not happen. Happens through all gears too.
  6. #6 Re: Hard shifting
    Sep 2015
    Sullivan, Mo
    I have a 06 gp 3.8L supercharged that has 3rd and 4th gear out the shop said. Not sure thats true. No engine lights are on?
  7. #7 Re: Hard shifting
    Oct 2015
    Western Pennsylvania
    I've had the same thing happen on my old 2001 GP and my 2004 Bonneville. Pull to the side of the road; key off - fixes it. Both cars went to 200K+ miles with no transmission issues (aside from this little anomaly)
    FourHondas
  1. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  2. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  3. shifting hard
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2011, 12:25 AM
  4. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
