Thread: Adding compass/temp mirror
Results 1 to 7 of 7
SomeDudeAtHome Adding compass/temp mirror 02-13-2014, 07:27 PM
Sven the Sexman Re: Adding compass/temp mirror 02-13-2014, 07:30 PM
SomeDudeAtHome Re: Adding compass/temp mirror 02-13-2014, 07:47 PM
Sven the Sexman Re: Adding compass/temp mirror 02-13-2014, 09:15 PM
lewis1952 Re: Adding compass/temp mirror 02-13-2014, 09:13 PM
SomeDudeAtHome Re: Adding compass/temp mirror 02-13-2014, 10:04 PM
Sven the Sexman Re: Adding compass/temp mirror 02-13-2014, 10:08 PM
  1. #1 Adding compass/temp mirror
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So I've seen the how-to on this subject but still have some questions. I have a 98 Gt. It's a very basic model GP. No leather, no HUD, basic mirror. Will I have the proper connections to make the mirror work or should I just skip it? Also from searching the forum I found that there's a connector near the battery that would make the temp sensor work. What are the chances I have this? I'm not even sure if these options were offered in 98 or not until the later 01+ models. Any info that people can give me would be great. Also if any one has done it and wants to explain how it went that'd be helpful to for me to decide if I want to try or not. Thanks
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Adding compass/temp mirror
    Mar 2012
    NC
    You'll have everything there to make the auto-dimming work. I like it to be clean and swapped the wires from the old mirror into the new connector. The temp is two wires that run out to the sensor in the front bumper. It's insanely easy...took me 30 minutes including running new wires.
  3. #3 Re: Adding compass/temp mirror
    Buffalo, NY
    I'm looking at them on ebay. They have the connector but the wires have been cut. Will I have to strip them and connect them to the wires that are up there already? I'm just having trouble finding good pictures to get a better idea of what it will be like.
  4. #4 Re: Adding compass/temp mirror
    Mar 2012
    NC
    Quote Originally Posted by SomeDudeAtHome View Post
    I took the terminals out of my connector and shoved them in the other connector.
  5. #5 Re: Adding compass/temp mirror
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Warning: the direction in the mirror may be opposite of the compass reading lol
  6. #6 Re: Adding compass/temp mirror
    Buffalo, NY
    Quote Originally Posted by lewis1952 View Post
    Why would it be backwards? Would it be as simple as switching some wires if they were connected backwards?
    And Sven, that's a good idea I didn't think about that. Looks like I'll go ahead and order one.
  7. #7 Re: Adding compass/temp mirror
    Mar 2012
    NC
    It's not just a good idea...it's the way it should be done. Slicing is for those who hack things. If it can be made to work without splicing, that's the proper route. LOL
  1. can you convert you car to onstar and adding the temp mirror?
    By Roanokegprix in forum General Tech Discussion
    Last Post: 03-29-2013, 06:19 PM
  2. Replacing plain mirror with compass/temp mirror
    By Musclecarguy in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2012, 03:35 PM
  3. Rear View Mirror doesn't display temp and/or compass
    By Silent Drifter in forum General Tech Discussion
    Last Post: 04-23-2010, 09:11 PM
  4. How do i add a temp/compass rearview mirror?
    By themagicdustman in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2010, 01:46 AM
  5. Mirror compass won't calibrate
    By SupahG33K in forum General Tech Discussion
    Last Post: 02-14-2010, 01:55 AM
