Thread: Wierd electrical problem on a 97 GTP
Results 1 to 2 of 2
  1. #1 Wierd electrical problem on a 97 GTP
    Jan 2014
    Hurley, MS
    This is going to be hard to explain. When I first cut the key on, I get the typical chime then something will click from the pass side dash. When it does this, the chime will stop along with the radio and then it comes right back. If I have the door open, I will also momentarily loose power to the dome lights. This has been happening for years now and it normally wouldn't be a big deal however it is effecting me being able to reprogram my key fob. I'll get right in the middle of the procedure and it will do it, causing me not to successfully reprogram the fob. I feel like whatever controls the run time of the radio when you turn off the key and whatever makes the dome light come on when you pull the key is going to be the culprit. I replaced the body control module and that didn't fix it. There is also a small black box under the glove box, could this be what I'm looking for?
    Thanks!
  2. #2 Re: Wierd electrical problem on a 97 GTP
    Jan 2014
    Hurley, MS
    Upon research, I'm understanding that the R.A.P. module controls this function. I'm going to look into replacing this module.
  1. electrical problem
    By Jordan Flowers in forum General Grand Prix Discussion
    Last Post: 07-12-2012, 10:15 AM
  2. wierd electrical problems
    By erod78 in forum General Tech Discussion
    Last Post: 06-07-2011, 08:16 AM
  3. Wierd Problem I guess Transmission
    By mschillingii in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2011, 07:57 AM
  4. wierd electrical problem
    By spiderjohn in forum 04+ Specifics
    Last Post: 08-27-2010, 10:09 PM
  5. 99 GTP WIERD problem...need HELP ASAP!!
    By LSXHP in forum General Tech Discussion
    Last Post: 02-21-2010, 04:12 AM
