Thread: Need emissions help, which option to go with?
Results 1 to 20 of 20
  1. #1 Need emissions help, which option to go with?
    Dec 2013
    Illinois
    I have an 02 gtp coupe, basic mods n bolt ons. Cai cone, upgraded pcm, bolt on downpipe, slp exhaust, headers, msd ign coilovers, ram air hood, my SES soon light is on with the dreaded po420. Tested and double checked and the catalytic coverter is fried. It was stock, so I assume that I shouldnt go with another one. There are many universal cats by magnaflow and flowmaster but does anyone have a good opinion on which one to go with or what to do? Ive seen dummy plugs but dont know 100% how those work either. Any advice helps! Thanks!
  2. #2 Re: Need emissions help, which option to go with?
    Most highflow cats will set that same code. They flow too well for what the car wants.
    You'd have to spend between 100-200 bucks for a higher quality cat converter to keep the light off for good. Those "dummy" plugs, emulators do not work on 01+ cars if I recall correctly.
  3. #3 Re: Need emissions help, which option to go with?
    walker catted down pipe would be the closest thing to stock.
    or get a zzp catted pipe and the do the fouler trick to fool the o2 sensor.
  4. #4 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    So I cant try the just fouler trick with the bad cat?
  5. #5 Re: Need emissions help, which option to go with?
    your cat is clogging up. it needs to get changed.
    the fouler tricks the pcm into thinking a high flow is not high flow.
  6. #6 Re: Need emissions help, which option to go with?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Will the fouler trick work if the cat has been completely deleted.
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: Need emissions help, which option to go with?
    not sure really. it may on the older models.
  8. #8 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    Im just so short on money scared If I put a high flow on that it won't work. Any legit suggestions where to start first?
  9. #9 Re: Need emissions help, which option to go with?
    Quote Originally Posted by indygrandprix View Post
    Sure will worth a shot. Got rid of my po420
    04 Comp G.
  10. #10 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    What year was it?
  11. #11 Re: Need emissions help, which option to go with?
    This will be for my 04. It's like $7 try it!
    04 Comp G.
  12. #12 Re: Need emissions help, which option to go with?
    Antioch, IL
    fouler worked on my mazda 3, double stacked though. all a fouler does it move the 02 further away from the exhaust.
    2009 Challenger SRT8
    Expert at being gay.
  13. #13 Re: Need emissions help, which option to go with?
    Dec 2013
    The fouler would probably work and is cheap enough to try if it doesnt work its not a big loss. You could also get or make an o2 sensor simulator. They work on damn near all cars that dont have an air pump. If your cat isnt plugged you dont really have to replace it if your only goal is to turn the light off.
    Sent from my SCH-R970 using Tapatalk
  14. #14 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    I will try the fouler since it's so cheap. Say a prayer for me! Lol thanks for all the help guys
    ! Any other suggestions are. welcome to
  15. #15 Re: Need emissions help, which option to go with?
    Omaha, NE
    So your cat is clogged, but you're not going to replace it? Are you aware of the negative impact a clogged cat can have on your engine?
  16. #16 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    Its not that im not going to deal with it or am ignoring it, but is dealing with that the most cost effectice way path to go down
    Until I pass emissions and get money replace it? Aftee I pass ill probably cut it out and replace with high flow and foul it
  17. #17 Re: Need emissions help, which option to go with?
    Dec 2013
    Just because he has a P0420 doesnt mean the cat is plugged. Usually when they are plugged you wont get a P0420 anyhow. More misfire codes and map/maf codes
  18. #18 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    Thats what I was thinking. Plus its not true dual its single to Y pipe and the exhaust flow is pretty great
  19. #19 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    Although being perfectly honest I have been having random and intermittent map/maf codes and hesitations while accelerating and erratic idle sometimes dying. All intermittent like right now it only dies once in a great while at idle it used to have to be in neutral and gassed to stay alive
  20. #20 Re: Need emissions help, which option to go with?
    Dec 2013
    Illinois
    ...what?
  1. exhaust/emissions
    By lewis1952 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-12-2013, 10:14 AM
  2. emissions codes help
    By Eric Whitter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 12:43 PM
  3. Oh, Emissions...
    By smcglaug18 in forum The Rant Forum
    Last Post: 08-17-2010, 08:51 AM
  4. Overkill Pcm, emissions
    By Perry125 in forum PCM Tuning
    Last Post: 02-25-2010, 09:42 PM
  5. emissions
    Last Post: 02-22-2009, 11:56 PM
